How to add and compile a new limiter scheme in openFOAM!? |
August 4, 2014, 13:50 |
Vahid E.
Rep Power: 12 |
I wanted to add a new limiter scheme such as "STACS" in openFOAM. I've already written the codes, however, I dont know how shall i compile and add it to openFOAM.
please note that I'm new in openFOAM environment and the interface is unfamiliar for me. thanks a million. |
August 5, 2014, 11:16 |
Bernhard
Rep Power: 22 |
Compile your code as a library, see e.g. $FOAM_SRC/finiteVolume
Use the files in Make as an example. Add the source .C files you need to compile in "files". Compile into a new library by "LIB = $(FOAM_USER_LIBBIN)/libmyLimiter" and see what dependencies you need for "options" (see, as an example $FOAM_SRC/finiteVolume/Make/options). Compile using wmake (or wmake libso for older versions). Add your library to the libs( ); list in your controlDict file. The TypeName you defined in the header file for your limiter should be available to select now. Good luck! |
August 6, 2014, 12:55 |
Vahid E.
Rep Power: 12 |
dear Bernhard,
I truly appreciate your guidance, the thing is Im new in openFOAM and i dont know how to compile my codes using "wmake". actually i donno how to compile new written codes to add to the original open library. can u please give me an heads up, a link or a quick note would suffice. thanks a million |
August 9, 2014, 22:50 |
Santiago Marquez Damian
Rep Power: 24 |
Santiago MÁRQUEZ DAMIÁN, Ph.D. Research Scientist Research Center for Computational Methods (CIMEC) - CONICET/UNL Tel: 54-342-4511594 Int. 7032 Colectora Ruta Nac. 168 / Paraje El Pozo (3000) Santa Fe - Argentina. http://www.cimec.org.ar |
August 12, 2014, 09:50 |
#7 | |
Bernhard
Rep Power: 22 |
I think it answers most of your questions. |
November 2, 2021, 03:36 |
#8 | |
Yifan Sun
compile, compile from source, scheme, schemes, wmake |
Add temperature to icoFoam in OpenFOAM 2.1.1 | magnounibo | OpenFOAM Programming & Development | 12 | February 17, 2020 06:28 |
How to add the extra term to k-epsilon model in OpenFOAM | COC | OpenFOAM Programming & Development | 0 | July 9, 2014 09:34 |
OpenFOAM 2.2.2 source pack installation on Xubuntu 13.10 | zordiack | OpenFOAM Installation | 1 | October 26, 2013 14:08 |
How to Install OpenFOAM on 64 Ubuntu 9.04 | hansel | OpenFOAM Installation | 62 | March 19, 2010 15:43 |
OpenFOAM Debian packaging current status problems and TODOs | oseen | OpenFOAM Installation | 9 | August 26, 2007 14:50 |
