wondering about patch.nf() and mesh.Sf().boundaryField()[patchID]
Like Tree1Likes
  • 1 Post By codder
Old   July 24, 2014, 14:08
Default wondering about patch.nf() and mesh.Sf().boundaryField()[patchID]
Eric Bryant
codder is on a distinguished road
Ultra confused by simple question...
Is the vectorField result of the following two expressions always identical ?
Within a patch I can access an ordered field of face normals:
patch.nf()
For that same patch with ID "patchID" but now within a solver, I can get face normals using:
mesh.Sf().boundaryField()[patchID] / mesh.magSf().boundaryField()[patchID]
I.e., are both these vectorFields ordered in the same sequence ??
I would like it very much if they are !! Thank you
randolph likes this.
codder is offline   Reply With Quote
Old   October 31, 2014, 05:08
Vignesh
vigneshTG is on a distinguished road
Dear Eric,
I also have the same doubt, did you find out the answer ? One more thing, can you tell me, how to access the normal vectors of a patch using patch.nf() ?
Thanks and Regards
Vignesh
vigneshTG is offline   Reply With Quote
Old   October 31, 2014, 08:14
chriss85 will become famous soon enough
They should have the same order as far as I know (but differences between single core and decomposed mesh may exist). Incase you want to access the cells next to the boundary, you will need a different index which can be found with the faceCells() function.
chriss85 is offline   Reply With Quote
Old   October 31, 2014, 14:12
Default yes it's true!
Eric Bryant
Sorry for not updating to this thread earlier. I'm not 100% sure (I didn't track down the C++) but having assumed them same for awhile I've never gone wrong.
So yes they share the same ordering.
[mesh manipulation] How to create patch after snappyHexMesh hsieh OpenFOAM Meshing & Mesh Conversion 33 July 17, 2017 09:15
IcoLagrangianFoam and particle forces davidpalko OpenFOAM Running, Solving & CFD 33 December 2, 2013 03:39
Relative Fluxes in icoDyMFoam deepsterblue OpenFOAM Running, Solving & CFD 7 July 20, 2012 03:39
IcoTopo mixerMeshslide Foam Code pilot OpenFOAM Running, Solving & CFD 6 September 19, 2006 14:31
just wondering. puck FLUENT 3 August 20, 2002 00:08
