Question regarding Energy equation in reactingFoam
Like Tree1Likes
  • 1 Post By Cyp
Old   July 3, 2014, 18:36
Default Question regarding Energy equation in reactingFoam
Daniel
Dan1788 is on a distinguished road
Dear all,
I am using reactingFoam for simulating a 2d axisymmetric jet flame. The following in the default energy equation in reactingFoam:
volScalarField& he = thermo.he();
fvScalarMatrix EEqn
fvm::ddt(rho, he) + mvConvection->fvmDiv(phi, he)
+ fvc::ddt(rho, K) + fvc::div(phi, K)
he.name() == "e"
? fvc::div
fvc::absolute(phi/fvc::interpolate(rho), U),
p,
"div(phiv,p)"
: -dpdt
- fvm::laplacian(turbulence->alphaEff(), he)
// - fvm::laplacian(turbulence->muEff(), he) // unit lewis no.
reaction->Sh()
+ fvOptions(rho, he)
EEqn.relax();
fvOptions.constrain(EEqn);
EEqn.solve();
fvOptions.correct(he);
thermo.correct();
Info<< "min/max(T) = "
<< min(T).value() << ", " << max(T).value() << endl;
What does the term "fvc::ddt(rho, K) + fvc::div(phi, K)" signify in the above, specifically what is the variable K in this equation?
Also what does the term "fvOptions(rho, he)" mean?
I would be really glad if anyone could help me out. Thanks!
Dan1788 is offline   Reply With Quote
Old   July 4, 2014, 17:52
Daniel
Foamers,
Anyone who can help? would really appreciate it
Old   August 1, 2014, 11:27
dkxls's Avatar
Armin
dkxls will become famous soon enough
Hi Daniel,
maybe at first a general advise: Please use the CODE tags, makes it much easier to read your post!
See also here: http://www.cfd-online.com/Forums/ope...tml#post424508
K is the kinetic energy; see the files createFields.H and pEqn.H in
applications/solvers/combustion/reactingFoam/
This "new" formulation of the energy equation got introduced with version 2.1, see OpenFOAM 2.0 for an alternative formulation of the energy equation (or a good text book will also do ).
If you don't know what it is you can forget about it at this point. See here for a more detailed explanation:
http://www.openfoam.org/version2.2.0/fvOptions.php
dkxls is offline   Reply With Quote
Old   August 2, 2014, 16:07
Daniel
Thanks Armin, this info certainly helped
I had another question regarding the momentum predictor statement in OpenFoam.
In the default version of reactingFoam (the solver I am using), the momentum predictor is turned off. Does this mean that the momentum equation is not solved ?? How is the velocity then computed ??
Please let me know if you have some knowledge about this. Thanks again!
Old   August 3, 2014, 01:46
Cyp
Cyprien
Cyp is on a distinguished road
Hi Daniel,
When your momentum predictor is set to off, indeed the matrix UEqn is not solved. However, you will notice in the source code that the matrix in created and updated with the flux of the previous time step. The variable H and rAU depend on this updated matrix and they are used to solve p.
U is then evaluated during the corrector step, at the end of pEqn file.
Best,
Cyprien
Cyp is offline   Reply With Quote
Old   August 5, 2014, 00:08
Daniel
Thanks Cyprien,
Can you suggest me some references or books where I can read about the pressure velocity coupling and the nomenclature that OpenFoam uses?
Old   August 5, 2014, 01:22
Cyp
Cyprien
Sure,
The reference for me remains the book of Patankar "Numerical Heat Transfer And Fluid Flow"
Another good reference, Ferziger and Peric "Computational Method for Fluid Dynamics"
The original paper of PISO is also instersting: Issa "Solution of the implicitly discretised fluid flow equations by operator-splitting"
More specific to OpenFOAM, there is the PhD dissertation of Hrvoje Jasak one of the main contributor to OpenFOAM "Error Analysis and Estimation for the Finite Volume Method with Application to Fluid Flows".
And a personal contribution: http://www.scribd.com/doc/181588911/...ion-of-icoFoam.
Cheers,
Cyprien
Dan1788 likes this.
Source Term due to evaporation in energy transport equation styleworker OpenFOAM Programming & Development 3 September 7, 2022 04:09
Energy equation for compressible flow majkl OpenFOAM Running, Solving & CFD 5 February 10, 2021 16:17
Energy equation in bouyant*Foam solvers makaveli_lcf OpenFOAM Running, Solving & CFD 0 December 21, 2009 05:09
Viscosity and the Energy Equation Rich Main CFD Forum 0 December 16, 2009 15:01
Energy equation Suresh Balasubramanian FLUENT 1 April 6, 2003 03:54
