IOdictionary with READ_IF_PRESENT, default option |
May 11, 2014, 11:13 |
CFDUser
Rep Power: 13 |
Hi All,
I wanted to define a define a something like this Code:
IOdictionary foo ( IOobject ( "foo", runTime.timeName(), runTime, IOobject::READ_IF_PRESENT, IOobject::NO_WRITE ), scalar( "foo", dimless, foo_inf ) ); Code:
volScalarField p ( IOobject ( "p", runTime.timeName(), mesh, IOobject::READ_IF_PRESENT, IOobject::AUTO_WRITE ), mesh, dimensionedScalar( "p", dimless, p_inf ) ); Code:
Making dependency list for source file hello.cpp SOURCE=hello.cpp ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam230/src/finiteVolume/lnInclude -g -IlnInclude -I. -I/opt/openfoam230/src/OpenFOAM/lnInclude -I/opt/openfoam230/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/hello.o hello.cpp: In function ‘int main(int, char**)’: hello.cpp:36:33: error: expression list treated as compound expression in functional cast [-fpermissive] hello.cpp:36:33: warning: left operand of comma operator has no effect [-Wunused-value] hello.cpp:36:33: warning: right operand of comma operator has no effect [-Wunused-value] hello.cpp:37:1: error: no matching function for call to ‘Foam::IOdictionary::IOdictionary(Foam::IOobject, Foam::scalar)’ hello.cpp:37:1: note: candidates are: /opt/openfoam230/src/OpenFOAM/lnInclude/IOdictionary.H:84:9: note: Foam::IOdictionary::IOdictionary(const Foam::IOobject&, Foam::Istream&) /opt/openfoam230/src/OpenFOAM/lnInclude/IOdictionary.H:84:9: note: no known conversion for argument 2 from ‘Foam::scalar {aka double}’ to ‘Foam::Istream&’ /opt/openfoam230/src/OpenFOAM/lnInclude/IOdictionary.H:81:9: note: Foam::IOdictionary::IOdictionary(const Foam::IOobject&, const Foam::dictionary&) /opt/openfoam230/src/OpenFOAM/lnInclude/IOdictionary.H:81:9: note: no known conversion for argument 2 from ‘Foam::scalar {aka double}’ to ‘const Foam::dictionary&’ /opt/openfoam230/src/OpenFOAM/lnInclude/IOdictionary.H:78:9: note: Foam::IOdictionary::IOdictionary(const Foam::IOobject&) /opt/openfoam230/src/OpenFOAM/lnInclude/IOdictionary.H:78:9: note: candidate expects 1 argument, 2 provided /opt/openfoam230/src/OpenFOAM/lnInclude/IOdictionary.H:54:7: note: Foam::IOdictionary::IOdictionary(const Foam::IOdictionary&) /opt/openfoam230/src/OpenFOAM/lnInclude/IOdictionary.H:54:7: note: candidate expects 1 argument, 2 provided make: *** [Make/linux64GccDPOpt/hello.o] Error 1 Regards, CFDUser_ |
May 13, 2014, 04:50 |
#2 | |
Tomislav Maric
Rep Power: 21 |
Don't guess - look at the code and find out. Find IOdictionary.H and take a look at the public class interface, and you will see the compilers and their signatures. You can use only those declared there.
When asking a question, prepare a SSCCE. |
May 13, 2014, 05:15 |
#3 | |
CFDUser
Rep Power: 13 |
I know both the definitions. Unfortunately I need to define such a IOdictionary for some advanced postprocessing purpose. Since READ_IF_PRESENT for IOdictionary is already defined, I am scared to change its constructor. I have something in my mind that is not straight forward to overcome this problem. So, just looking for better suggestions if some people may already overcome this problem. Thank you, Regards, CFDUser_ |
May 13, 2014, 05:21 |
Tomislav Maric
Rep Power: 21 |
Do you need an object that has a scalar and has a IOdictionary?
You should never change the classes to make them run the way you want - use object oriented principles. Either inherit or compose classes. What you could do is to write a new class that has an IOdictionary attribute and a scalar attribute. Waning: the code below I typed, I didn't test it: Code:
class enhancedScalar { IOdictionary dict_; scalar value_; public: enhancedScalar(const IOdictionary& io, scalar s) : dict_(io), value(s) {} } Code:
enhancedScalar es ( IOdictionary ( ... parameters ), scalar (11) ); There are multiple options - the real question is: what exactly do you want to do? If you answer this question without using class names, I may be able to help you.
May 13, 2014, 05:24 |
unfortunately "I wanted to define a define a something like this" does not quite describe what you are trying to achieve. Would you like to set scalar foo to certain value if there is no dictionary? There already was an attempt to guess the reason you'd like to create the dictionary your way, it was not quite successful, maybe you can describe your problem in more details? Upd. It seems I was writing the post too long |
May 13, 2014, 05:36 |
#6 | |
CFDUser
Rep Power: 13 |
In between, I have few IOdictionary objects in some time directories. let me show one of such object. Code:
FoamFile { version 2.0; format ascii; class dictionary; location "1e-3"; object foo; } foo 34 ( 1 2 3 . . . 34 ); If I define a IOdictionary foo(... READ_IF_PRESENT....), It will throw an error if file is not there in time dir. That is the reason i wanted something like Geom field. One more, is there any option like push_back in OpenFoam? If so please describe with simple example. Thank you Regards, CFDUser_ |
May 13, 2014, 05:40 |
Tomislav Maric
Rep Power: 21 |
I agree with alexey, let us know what your actual goal is - it might be that the implementation you have in mind will not work or is not the best one, discussing the actual goal is allways better than implementation details.
Don't try to implement the example that I proposed unless that is really what you need. This is only valid if your new class should compose both IOdictionary and a scalar. For instance, if you want the new object to be modifiable at run-time, then I would propose you inherit from IOobject instead. What are you conceptually trying to accomplish?
May 13, 2014, 05:46 |
CFDUser
Rep Power: 13 |
I am trying to collect the lagrangian particles information in a defined region.
Hope this description will clear what i am trying to do. Regards, CFDUser_ |
May 13, 2014, 05:48 |
#9 | |
Tomislav Maric
Rep Power: 21 |
You store the lagrangian particles information as dictionaries? So that each particle has a dictionary and then a scalar, a vector, or whatever else you want the particle to carry?
May 13, 2014, 05:49 |
#10 |
CFDUser
Rep Power: 13 |
May 13, 2014, 06:04 |
#11 |
Tomislav Maric
Rep Power: 21 |
My first impression is that using dictionary for this causes an unnecessary overhead. Lookup operations on millions of particles will destroy your efficiency, and dictionary is a heap based data structure - which means that heap allocations will then put the last bullet in the forhead of the efficiency of your code.
Before proceeding, note that I have 0 experience in working with lagrangian stuff in OpenFOAM, all what follows comes from browsing the code. If you take a look at : Code:
/src/lagrangian/basic Code:
Class Foam::indexedParticle Description Adds label index to base particle Code:
class indexedParticle : public particle { // Private data label index_; The thing that you want to compose - say particleProperty you should also encapsulate into a class. This way you'll be able to store different things, as with the dictionary, without the additional heap allocation + lookup costs. (heap allocation within the dict - not sure what data structure is used to store particles in lagrangian, I never touched it) You should IMHO then statically at compile time choose the particle property and have an efficient code. You could theoretically add runtime selection to the particleProperty, again, at costs of efficiency. I would not do that. Anyway, since you are thinking about extending particles with additional information, the way above is how it is done in OF, and how I would do it if I were you. I would go away from dictionaries. Good luck! Hope this helps
May 13, 2014, 06:14 |
#12 | |
CFDUser
Rep Power: 13 |
Thing is that now I have good enough postprocessing stuff which will do all these calculations at runtime and as you said efficient way to do. But what I am trying now is postprocessing available results. I have loads of results to analyze and I need such a IOdictionary to make things easy. Regards, CFDUser_ |
May 22, 2014, 11:14 |
#13 |
Vitor Vasconcelos
Rep Power: 14 |
Hello all,
I suppose this thread is a good place to ask this question: how does READ_IF_PRESENT works? http://openfoamwiki.net/index.php/In...IOobject_class says "It reads the object from Istream if Istream exists, otherwise doesn't. An error message is produced only if Istream exists but can't be read." So, my problem: I added a source-term for chtMultiRegionSimpleFoam and I want is the solver tries to read Q file. If the file is there the solver reads the file. This works fine. However, I have cases where the file will not be present and, in this case, I wish to create a volScalarField of zeros and I'll have no source-term. To achieve this idea, I'm trying to use this code: Code:
IOobject Qfile ( "Q", runTime.timeName(), solidRegions[i], IOobject::READ_IF_PRESENT, IOobject::AUTO_WRITE ); Code:
--> FOAM FATAL IO ERROR: cannot find file file: /home/vitors/workspace/tutorials/acople1/0/fuel/Q at line 0. ... Thanks a lot! Vitor |
May 22, 2014, 15:27 |
#14 | |
CFDUser
Rep Power: 13 |
problem is IOobject is designed in such a way that it should always look for the variable you wanted to read. use some basic c++ language to find the directory/file we wanted to read. if present continue else break. below link will give you some hint http://stackoverflow.com/questions/2...-change-output |
May 22, 2014, 17:43 |
#15 |
Vitor Vasconcelos
Rep Power: 14 |
Thank you very much CFDUser.
Actually, I could solve my problem. But I am always wondering when use OpenFOAM classes or std C++ library. I always start thinking using OpenFOAM classes is the best option since I'm inside OpenFOAM. But its classes are always so "tight" conceived (try to instantiate a volScalarField of zeros, or use istream to read a file or check if it existes, or use OpenFoam's fileName to get the file string...). I'm always pushed to use std C++ after struggling with OpenFOAM classes... Cheers, Vitor |
Error message: Insufficient Catalogue Size | Paresh Jain | CFX | 33 | August 16, 2024 05:09 |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 05:45 |
Problems with CEL (guess it's simple to solve) | Felggv | CFX | 22 | March 26, 2019 16:42 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
transient simulation of a rotating rectangle | icesniffer | CFX | 1 | August 8, 2009 07:25 |
