Set a value in all cells contained in a cellSet |
May 7, 2014, 06:34 |
Dragos
Rep Power: 20 |
Hello everyone,
I have this issue that I could not find an answer for it on the forum: how to set a value in a field variable, but only in cells belonging to a certain cellSet? A simple example is that I want to patch a scalar field with value 1 in a subdomain of my computational domain. This is of course done easy with setFields, but I need a snippet, and until know I have this: Code:
//generate the scalar field, initialized with 0.0 volScalarField Tij( IOobject ( "Tij", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::AUTO_WRITE ), (mesh.C() & mesh.C())*0.0 ); //define the limits of the subdomain where I want to patch with 1.0 scalar xmin = -0.015; scalar xmax = 0.035; scalar ymin = -0.015; scalar ymax = 0.035; scalar zmin = -0.0; scalar zmax = 0.02; //patch the cells that have the centroid inside the desired domain forAll(Tij,cellI) { vector centroid = Tij.mesh().C()[cellI]; if(centroid[0] >= xmin && centroid[0] <= xmax && centroid[1] >= ymin && centroid[1] <= ymax && centroid[2] >= zmin && centroid[2] <= zmax) Tij[cellI] = 1.0; } Code:
//generate the scalar field, initialized with 0.0 volScalarField Tij( IOobject ( "Tij", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::AUTO_WRITE ), (mesh.C() & mesh.C())*0.0 ); //read a previously defined cellSet (the set was defined using the //utility setSet) cellSet cSet(mesh,"box"); //patch all the cells contained within cSet with 1.0 forAll(cSet,cellI) { Tij[cSet[cellI]] = 1.0; } Any hints? Dragos Last edited by dmoroian; May 7, 2014 at 14:09. |
May 8, 2014, 08:34 |
Tomislav Maric
Rep Power: 21 |
A cellSet is a HashSet is a HashTable is a HashTableCore. If you follow the inheritance and the typedef used for the HashSet, you'll see that the cellSet relies on the uniqueness of keys in the HashSet to prevent duplication of the stored cell IDs. You can access the cell labels by accessing the HashTable:toc() table of contents.
Here is the working example: Code:
#include "fvCFD.H" #include "cellSet.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Main program: int main(int argc, char *argv[]) { #include "setRootCase.H" #include "createTime.H" #include "createMesh.H" // The cellSet requires a simulation case, since all constructors take an // IOobject as the argument. cellSet testCells( IOobject ( "testCells", "constant/polyMesh/sets", mesh, IOobject::NO_READ, IOobject::AUTO_WRITE ) ); // HashTable<-HashSet<-cellSet, so there is no need to first create the // cell set using the 'setSet' app, you can do it for testing purposes manually. testCells.insert(0); testCells.insert(1); testCells.insert(3); testCells.insert(4); testCells.insert(5); testCells.insert(6); testCells.insert(7); // Note the repeating ID. testCells.insert(7); // Note the repeating ID. testCells.insert(7); // Note the repeating ID. testCells.insert(34); // HashSet uses unique keys, so the cellSet is based on it, to prevent repeating // cell IDs. // Write the cellSet using the regIOobject inheritance path. testCells.write(); // Since a cellSet is a HashTable is a HashTableCore, use toc() to access keys. const labelList& cells = testCells.toc(); // Here are your cell IDs. forAll(cells, I) { Info << cells[I] << endl; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Info<< "\nEnd\n" << endl; return 0; } // ************************************************************************* //
When asking a question, prepare a SSCCE. |
May 8, 2014, 10:55 |
Dragos
Rep Power: 20 |
It works great!
Thanks! |
Problem with divergence | TDK | FLUENT | 13 | December 14, 2018 07:00 |
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel | colinB | OpenFOAM Meshing & Mesh Conversion | 14 | December 12, 2018 09:07 |
correction of Grub after installing Windows XP and 8 | immortality | Lounge | 20 | January 5, 2014 18:41 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 10:53 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
