Adding Boussinesq Approximation to multiphaseEulerFoam?
Like Tree1Likes
  • 1 Post By dschmidt
Old   March 18, 2014, 10:38
Default Adding Boussinesq Approximation to multiphaseEulerFoam?
Dominik Schmidt
dschmidt is on a distinguished road
I'm quite new to openFoam, but I'm trying to implement the Boussinesq approximation into the multiphaseEulerFoam Solver (OF 2.2.x).
My first step was to add a simple temperature-equation for the hole system, including the calculation of rhok, as in other Boussinesq solvers.
TEqn.H:
       fvScalarMatrix TEqn
                fvm::ddt(T)
                + fvm::div(phi, T)
                - fvm::laplacian(DT, T)
        TEqn.relax();
        TEqn.solve();
        rhok = 1.0 - beta*(T - TRef);
As far as I could see, the gravity term is dealt within the pressure-equation, though I only modified two lines of code:
pEqn.H - lines 85-89
phiHbyAs[phasei] +=
      rAlphaAUfs[phasei]
       fluid.surfaceTension(phase)*mesh.magSf()/phase.rho()
       + /*(g & mesh.Sf())*/      fvc::interpolate(rhok)*(g & mesh.Sf())/phase.rho()
pEqn.H - lines 235-241
phase.U() =
  HbyAs[phasei]
   + fvc::reconstruct
       rAlphaAUfs[phasei]*/*(g & mesh.Sf())*/ fvc::interpolate(rhok)*(g & mesh.Sf())/phase.rho()
      + rAlphaAUfs[phasei]*mSfGradp/phase.rho()
Finally, in multiphaseEulerFoam.C I placed the "#include TEqn.H" right after the UEqn.
So my first question is, if this implementation makes sense or am I missing something important?
I also made some modifications to TEqn based on http://www.cfd-online.com/Forums/ope...er-solver.html
volScalarField rhoCp = fluid.rho()*fluid.Cp();
surfaceScalarField kByCpf = fvc::interpolate(fluid.kappa()/rhoCp + sgsModel->nut()/fluid.Prt());
 fvScalarMatrix TEqn
   fvm::ddt(T)
 + fvm::div(phi, T)
 - fvm::laplacian(kByCpf, T)
TEqn.relax();
TEqn.solve();
And tried to validate the modified multiphsaeEulerFoam against buoyantBoussinesqPimpleFoam, but as you can see in the picture, the temperature evolution is different (looks like lower Rayleigh Nr. with mod.MultiphaseSolver?), and so the velocities are different, too.
left: buoyantBoussinesqPimpleFoam | right: multiphaseEulerFoam-Boussinesq
Setup:
Fluid: Air (rho: 1.205; beta: 3.43e-03; Pr/Prt 0.71, nu: 15.11e-6; Cp: 1.005, kappa(multiphase): 0.0257)
T_left: 303 K
T_right: 283 K
TRef: 293 K
I believe/hope the reason can be found in the different TEqn-implementations, rather then in the PEqn, but would be glad if someone could support this assumption, and suggests an easy way to validate the multiphaseBoussinesq-version.
My first idea would be to edit the TEqn of PimpleBoussinesq Solver so it matches the TEqn with fixed diffusion coeff. (DT) and compare the results with the modified multiphaseSolver.
\\EDIT:
After implementing the same TEqn in both solvers I couldn't see much difference. Then I remembered that multiphaseEulerFoam
always has a residual phase fraction for overcoming the problems with non-phase intensive handling of the momentum equations.
So I edited the transport properties for the second phase (alpha uniform 0) to match the ones of the "alpha uniform 1" phase (air).
After that the temperature distribution looks more like the one with buoyantBoussinesqPimpleFoam, but the velocities are still lower
So the differences seem to be related to the fact, that multiphaseEulerFoam is not designed for dealing with a single phase system ?
Thanks !
tom_flint2012 likes this.
dschmidt is offline   Reply With Quote
Old   January 16, 2017, 17:40
Default Why no change to UEqns.h
Thomas Flint
tom_flint2012 is on a distinguished road
Hello.
I have implemented your approach for the boussinsq approximation in multiphaseeulerfoam.
Please may you explain to me why you don't add a term in the UEqns.h file. Your advice would be greatly appreciated.
Best regards,
Tom
EDIT
My sincere apologies, I've just seen the peqn.h file again where the ueqns are modified. Apologies for any inconvenience.
Best regards,
Tom
tom_flint2012 is offline   Reply With Quote
InterFoam with boussinesq approximation sinusmontis OpenFOAM Running, Solving & CFD 2 October 25, 2020 13:21
Boussinesq approximation, help please! engahmed FLUENT 0 May 20, 2010 12:25
Question on boussinesq approximation panos_metal FLUENT 1 January 11, 2010 12:18
boussinesq approximation jamal FLUENT 2 March 25, 2008 09:57
Boussinesq approximation again Gabriel Main CFD Forum 3 May 11, 2000 10:24
