adding Energy eqn to the porousSimpleFoam solver
Like Tree1Likes
  • 1 Post By adambarfi
Old   March 17, 2014, 10:13
Default adding Energy eqn to the porousSimpleFoam solver
adambarfi's Avatar
Mostafa Mahmoudi
adambarfi is on a distinguished road
Send a message via Yahoo to adambarfi Send a message via Skype™ to adambarfi
hi everybody,
I'm Trying to add Energy Eqn to the porousSimpleFoam solver and I'm encountering some problems. I want to solve natural convection in a porous zone. I added TEqn and necessary terms to momentum equation, but when I wmake it the below error appeared:
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/finiteVolume/lnInclude/fvMatrix.C:1862:34: note: template<class Type> Foam::tmp<Foam::fvMatrix<Type> > Foam::operator+(const Foam::tmp<Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh> >&, const Foam::tmp<Foam::fvMatrix<Type> >&)
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/finiteVolume/lnInclude/fvMatrix.C:2101:34: note: template<class Type> Foam::tmp<Foam::fvMatrix<Type> > Foam::operator+(const Foam::fvMatrix<Type>&, const Foam::dimensioned<Type>&)
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/finiteVolume/lnInclude/fvMatrix.C:2114:34: note: template<class Type> Foam::tmp<Foam::fvMatrix<Type> > Foam::operator+(const Foam::tmp<Foam::fvMatrix<Type> >&, const Foam::dimensioned<Type>&)
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/finiteVolume/lnInclude/fvMatrix.C:2127:34: note: template<class Type> Foam::tmp<Foam::fvMatrix<Type> > Foam::operator+(const Foam::dimensioned<Type>&, const Foam::fvMatrix<Type>&)
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/finiteVolume/lnInclude/fvMatrix.C:2140:34: note: template<class Type> Foam::tmp<Foam::fvMatrix<Type> > Foam::operator+(const Foam::dimensioned<Type>&, const Foam::tmp<Foam::fvMatrix<Type> >&)
make: *** [Make/linux64GccDPOpt/bbpsfMy.o] Error 1
I can't understand where is the problem. anybody knows from where does this error originate?
Best,
Mostafa
yesaswi92 likes this.
adambarfi is offline   Reply With Quote
Old   March 26, 2014, 01:56
adambarfi's Avatar
Mostafa Mahmoudi
and finally, after lots of endeavor, I couldn't do that!!!!
so I decided to write the code in my way and don't using the porousZone of OF! but I have a big problem:
I don't know how to specify an equation for a region that I defined it in my mesh?!?! how can I tell OF that the zone, for example, named PorousZ have different governing equation with the other zone? or how can I use a source term in my equations that have a coefficient like 'beta':
beta=0 if zone=FluidZ
beta=1 if zone=PorousZ
thanks
Mostafa
Old   March 26, 2014, 03:52
Christian Butcher
chrisb2244 is on a distinguished road
Dear Mostafa,
I haven't tried doing this, but my guess is that you might find your second method easier.
If you can write a set of equations which is applied to all of your mesh, with all of the mesh being affected by a source term, which is multiplied by zero for your FluidZ zone, then that should be fairly simple?
Assuming that your zones are constant in time, you can use something like
volScalarField betaMultiplier
	IOobject
		"beta",
		runTime.timeName(),
		mesh,
		IOobject::NO_READ,
		IOobject::AUTO_WRITE,
		true
	mesh,
	dimensionedScalar
		"beta",
		dimensionSet(0, 0, 0, 0, 0, 0, 0),
		0.0
	// Some boundary types here - I guess these might not matter?
and then set values using something like
forAll(mesh.cellCentres(), cellI)
    if (some test for zones)
          betaMultiplier.internalField()[cellI] = 1;
    else
          betaMultiplier.internalField()[cellI] = 0;
Like I said, I haven't tested this for what you're trying to do, and I don't know anything about cellZones, but I used a similar setup to generate an alpha field in a class I have recently written. (Seemingly the alphaGeneration class works nicely, although I have numerous other (I think unrelated) problems with my solver! :P )
chrisb2244 is offline   Reply With Quote
Old   March 31, 2014, 21:14
Yesaswi
yesaswi92 is on a distinguished road
I am also trying to do the same. Did you figure out how to do it??
yesaswi92 is offline   Reply With Quote
Old   April 1, 2014, 05:17
Olivier
olivierG is on a distinguished road
Why don't you use buoyantSimpleFoam / buoyantBoussinesqSimpleFoam ?
For porosity, just use fvOptions, with explicitPorositySource type.
Regards,
olivier
olivierG is offline   Reply With Quote
Old   April 1, 2014, 05:29
adambarfi's Avatar
Mostafa Mahmoudi
Regards,
olivier
Hi Olivier,
AFAIK, fvOptions is just for OF-2.2.x, am I right?
It's a good idea, but I haven't enough information about how fvOptions works!
can you please give me some information?
Thanks a lot for your idea,
Mostafa
Old   April 1, 2014, 05:49
Olivier
hello,
fvOption should work for at least OF 2.2 and 2.3
Here is an exemple file for fvOption with porosity, and also with the topoSetDict. Both should be in system.
Just run "topoSet" to create the cellZone before running the solver.
regards,
olivier
File Type: zip fvOptions.zip (706 Bytes, 16 views)
File Type: zip topoSetDict.zip (569 Bytes, 13 views)
chtMultiRegionSimpleFoam samiam1000 OpenFOAM Running, Solving & CFD 39 March 31, 2016 09:43
Adding Radiation to a turbulent solver MasAmi OpenFOAM Running, Solving & CFD 0 October 25, 2013 03:36
energy eqn + constant fluid properties cfx_user Main CFD Forum 1 March 6, 2013 08:13
Different ans of poisson eqn with different solver Quarkz Main CFD Forum 0 October 6, 2005 12:49
Solver for poisson eqn in FVM? Mudpack, fishpack.? zonexo Main CFD Forum 0 October 5, 2005 20:11
