Eclipse flags errors even though Compile works |
Olabanji
Rep Power: 13 ![]() |
Hi Foamers,
I am not sure if this problem has been fixed lately but it still disturbs me. Details below: When I import a solver for efficient editing in eclipse and compile, everything works fine but I still get lots of flag warnings e.g. Symbol 'runTime' could not be resolved, Symbol 'mesh' could not be resolved and so many more multiple marker. I have surfed the net for any possible solution, still same result. By the way, I use
Attached is a snapshot of 'icoFoam.C' showing lots of error flags even though it compiles fine. Any help would be much appreciated. Regards. |
Mohammad Reza
Rep Power: 10 ![]() |
Hi banji
Have you solved the problem? I'm searching for some solution too. regards |
Olabanji
#4 | |
Kevin van As
Rep Power: 20 ![]() |
http://www.cfd-online.com/Forums/ope...tml#post591519 |
Mohammad Reza
Thanks for your wonderful solution!!
#6 | |
Mohammad Reza
Ali
Rep Power: 12 ![]() |
Hi
Do you know if this will work in CLion? I think it's the same idea as eclipse. Ali |
eclipse, flag, openfoam, resolved, source code |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Custom BC compile warnings & Runtime Errors | Hisham | OpenFOAM Programming & Development | 5 | November 2, 2011 02:48 |
PV3FoamReader compile error.... | PEM_GUY | OpenFOAM Installation | 6 | April 5, 2010 17:22 |
interpret works fine but compile doesn't | Jan Balemans | FLUENT | 0 | March 14, 2008 09:41 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
