Call external code (functionObject execute() like) within pimple.loop()
Like Tree2Likes
  • 2 Post By jherb
Old   January 28, 2014, 13:53
Default Call external code (functionObject execute() like) within pimple.loop()
Joachim Herb
jherb is on a distinguished road
Hello OpenFOAM colleagues,
I'm looking for a way to call code defined (as e.g. functionObject) in the controlDict (ideally a python function using pythonIntegration in swak4Foam) from within the pimple.loop() in a transient solver. Or in (hopefully) simple words: Call a function after each iteration of the outer corrector loop within one time step.
functionObjects or pythonIntegrationFunctionObjects are only called once per time step.
What is the easiest way to achieve this? Ideally I do not want to overwrite the pimpleControl class but add something (a call to functionObject.execute() ???) to the solver or even better use something already build in.
Thank you for any hints/help.
Joachim
jherb is offline   Reply With Quote
Old   January 30, 2014, 07:40
Joachim Herb
I found a way to do this: Add the following code to (within) the pimple.loop():
            functionObjectList& fol = runTime.functionObjects();
            fol.execute(false);
(you have to add #include "functionObjectList.H" at the beginning of your solver).
Add the following to your controlDict and the executeCode is called during each step of your pimple.loop:
functions {
    pythonSimple
        type pythonIntegration;
        //        debugPythonWrapper 1; // switching on
        startCode "print 'Starting';a=0; print dir()";
        executeCode "a+=1; print 'a:',a";
        endCode "print 'Never been here'";
        //        tolerateExceptions true;
        parallelMasterOnly false;
        isParallelized true;
        useNumpy false;
        useIPython true;
    pythonOutput
        startCode "";
        executeCode "print 'timeName :',timeName,'outputTime:',outputTime";
        endCode "print 'timeName :',timeName,'outputTime:',outputTime";
        parallelMasterOnly true;
        useNumpy false;
        useIPython true;
libs (
    "libgroovyBC.so"
    "libswakPythonIntegration.so"
    "libswakFunctionObjects.so"
wyldckat and kamakura117 like this.
Old   January 30, 2014, 18:01
Retired Super Moderator
Bruno Santos
Greetings Joachim,
I noticed your feature request on the bug tracker: http://www.openfoam.org/mantisbt/view.php?id=1145
Just to let you know that a very similar feature request was asked about back in August 2012: http://www.openfoam.org/mantisbt/view.php?id=641
Best regards,
Bruno
Old   January 30, 2014, 18:24
Joachim Herb
Thank you for the information. Indeed the old bug looks somehow similar to what I would like to do. The final goal is to couple OpenFOAM with an external solver (for 1-d thermohydraulics). For the stability of the coupling it is necessary to exchange information on the boundaries more than once per time step.
Old   January 30, 2014, 18:36
Bruno Santos
Have you checked the tutorial "./heatTransfer/buoyantSimpleFoam/externalCoupledCavity" in OpenFOAM 2.2, to see if it would work for you?
Old   January 31, 2014, 10:21
Joachim Herb
Thank you for your hint. I would like to avoid the exchange via file system but yes, I was able to run this example and also the "hot room" of the buoyantPimpleFoam tutorials and the data are exchanged after each step of the outer corrector loop within a time step.
Old   February 1, 2014, 18:33
Bruno Santos
Hi Joachim,
Have a look into this thread: http://www.cfd-online.com/Forums/ope...lue-facei.html - the idea given there is that you can use that tutorial and the associated boundary condition as a basis for your connection between applications. In other words, you would have to copy-paste-modify the source code of the boundary condition to suit your needs.
Nonetheless, now I'm looking into the source code for the boundary condition, it does feel that the solution you're using with Python is somewhat easier to implement.
Best regards,
Bruno
functionobjects, pimple, swak4foam
What is the Better Way to Do CFD? John C. Chien Main CFD Forum 54 April 23, 2001 09:10
Open source CFD code development, possible? Dr. Yazid Bindar Main CFD Forum 27 July 18, 2000 01:18
State of the art in CFD technology Juan Carlos GARCIA SALAS Main CFD Forum 39 November 1, 1999 15:34
Who's ok for an Open Source CFD project ? Viet Main CFD Forum 16 July 26, 1999 16:57
What kind of Cmmercial CFD code you feel well? Lans Main CFD Forum 13 October 27, 1998 11:20
