Confusion with magSqr in turbulence model kOmegaSST - OpenFOAM 2.2.x |
Rep Power: 15 ![]() |
For the incompressible RAS I would like to implement the k-omega SST turbulence model by Menter with the vorticity source term. You can find the theory on it here: http://turbmodels.larc.nasa.gov/sst.html
So I had a look at the standard kOmegaSST turbulence model which is implemented into OpenFOAM. The only thing I have to change is the production of turbulent kinetic energy. In the kOmegaSST.C on lines 412-413 the production G is defined as: Code:
const volScalarField S2(2*magSqr(symm(fvc::grad(U_)))); volScalarField G(GName(), nut_*S2); But I can't really make the conversion to the standard formula that I know, which will look like this for incompressible RAS: G=nut*dUi/dxj*(dUi/dxj+dUj/dxi) Eqn. 2 So my question is why is there a magSqr in Eqn. 1? This looks different from the definition that I know. Shouldn't it be more like this: Code:
const volScalarField S(2*mag(symm(fvc::grad(U_)))); volScalarField G(GName(), nut_*S*fvc::grad(U_)); Thanks in advance. Kind regards, Andreas Last edited by A_Pete; January 7, 2014 at 09:01. Reason: fvc:: missing in Eqn. 3 |
Gerhard Holzinger
Rep Power: 28 ![]() ![]() |
take a look at the attached pdf. In Sect. 39.4.7 I do the math to look whether the formular for the production term for the turbulent kinetic energy of the kEpsilon model in OpenFOAM is equal to the formula stated in the book of Ferzinger. The equations you posted look the same as they are in the question I answered. |
Hi Gerhard and thank you very much for your answer,
yes the equations of Ferziger, Perić is the same that I stated, as well as the implementation in OpenFOAM. This is the proof I was looking for! |
#4 | |
Rep Power: 0 ![]() |
i would be interested on the whole "someMath" document ![]() regards Michael |
Gerhard Holzinger
The whole document can be found here http://www.cfd-online.com/Forums/ope...-openfoam.html
gamma-ReTheta turbulence model for predicting transitional flows | FelixL | OpenFOAM Programming & Development | 123 | August 30, 2022 11:50 |
Implement an les turbulence model | pante | OpenFOAM Programming & Development | 19 | December 5, 2014 16:16 |
Turbulent frequency equation for compressible kOmegaSST turbulence model | Bojan | OpenFOAM Programming & Development | 1 | September 6, 2013 06:45 |
What model of turbulence choose to study an external aerodynamics case | raffale | OpenFOAM | 0 | August 23, 2012 05:45 |
How can run MRFSimpleFoam with KOmegaSST turbulence model | waynezw0618 | OpenFOAM Running, Solving & CFD | 0 | April 21, 2008 04:40 |
