How to add Brinkman Term to porousSimpleFoam solver?
Like Tree1Likes
  • 1 Post By AmirBaqa1987
Old   December 24, 2013, 04:34
Default How to add Brinkman Term to porousSimpleFoam solver?
Arjang Behnoud
AmirBaqa1987 is on a distinguished road
Hi everyone.
the momentum equation of porousSimpleFoam is :
the last two terms are darcy and Forchheimer resistance in order.UEqn.h and PEqn.h in solver are:
Ueqn.H
 tmp<fvVectorMatrix> UEqn
        fvm::div(phi, U)
      + turbulence->divDevReff(U)
    UEqn().relax();
    // Include the porous media resistance and solve the momentum equation
    // either implicit in the tensorial resistance or transport using by
    // including the spherical part of the resistance in the momentum diagonal
    tmp<volScalarField> trAU;
    tmp<volTensorField> trTU;
    if (pressureImplicitPorosity)
        tmp<volTensorField> tTU = tensor(I)*UEqn().A();
        pZones.addResistance(UEqn(), tTU());
        trTU = inv(tTU());
        trTU().rename("rAU");
        volVectorField gradp = fvc::grad(p);
        for (int UCorr=0; UCorr<nUCorr; UCorr++)
            U = trTU() & (UEqn().H() - gradp);
        U.correctBoundaryConditions();
    else
        pZones.addResistance(UEqn());
        eqnResidual = solve
            UEqn() == -fvc::grad(p)
        ). initialResidual();
        maxResidual = max(eqnResidual, maxResidual);
        trAU = 1.0/UEqn().A();
        trAU().rename("rAU");
PEqn.H
    U = trTU()&UEqn().H();
else
    U = trAU()*UEqn().H();
UEqn.clear();
phi = fvc::interpolate(U) & mesh.Sf();
adjustPhi(phi, U, p);
for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++)
    tmp<fvScalarMatrix> tpEqn;
        tpEqn = (fvm::laplacian(trTU(), p) == fvc::div(phi));
    else
        tpEqn = (fvm::laplacian(trAU(), p) == fvc::div(phi));
    tpEqn().setReference(pRefCell, pRefValue);
    // retain the residual from the first iteration
    if (nonOrth == 0)
        eqnResidual = tpEqn().solve().initialResidual();
    else
        tpEqn().solve();
    if (nonOrth == nNonOrthCorr)
        phi -= tpEqn().flux();
#include "continuityErrs.H"
// Explicitly relax pressure for momentum corrector
p.relax();
    U -= trTU()&fvc::grad(p);
else
    U -= trAU()*fvc::grad(p);
now I want to add Brinkman Term to momentum equation, I mean:
for this I've just define in createFields.H and modify UEqn.H like below:
UEqn.H
            fvm::div(phi, U)
         -  fvm::laplacian(mue,U)
am I right?
shouldn't I modify PEqn.H?
thanks a lot.
your hints are appreciated .
Best Regards,
Arjang
Caio Martins likes this.
AmirBaqa1987 is offline   Reply With Quote
Old   December 25, 2013, 02:39
Arjang Behnoud
I'm still waiting for HELP.
Old   April 30, 2016, 15:59
Caio Martins Ramos de Oliveira
Caio Martins is on a distinguished road
Were you able to find a solution? Were you right?
Caio Martins is offline   Reply With Quote
[PyFoam] and paraview eelcovv OpenFOAM Community Contributions 28 May 30, 2016 10:23
A problem with porousSimpleFoam solver AmirBaqa1987 OpenFOAM Running, Solving & CFD 4 October 30, 2015 11:54
How to add Radiation to existing buoyantBoussinesqSimpleFoam solver MasAmi OpenFOAM Running, Solving & CFD 4 January 16, 2014 07:17
Add source term in alphaEqn.H of interFoam tayo OpenFOAM 1 October 23, 2013 04:40
add source term in energy equation chaolian OpenFOAM Programming & Development 4 November 8, 2012 23:22
