Viscositymodel tutorial, problems when changing test case to cavity |
December 8, 2013, 10:39 |
Rep Power: 13 |
I have recently created a simulation which has a temperature dependant viscosity: (http://www.tfd.chalmers.se/~hani/kur...nFoam%20v2.pdf) The solver and test case both worked fine and compiled okay, however when I tried to modify the simulation to apply this temperature dependant viscosity on the cavity tutorial geometry I had gotten an error: Code:
--> FOAM FATAL IO ERROR: Unable to set reference cell for field p Please supply either pRefCell or pRefPoint file: /home/sk/OpenFOAM/sk-2.2.1/run/tvCavity/system/fvSolution.SIMPLE from line 80 to line 87. From function void Foam::setRefCell ( const volScalarField&, const volScalarField&, const dictionary&, label& scalar&, bool ) in file cfdTools/general/findRefCell/findRefCell.C at line 125. FOAM exiting Code:
SIMPLE { nNonOrthogonalCorrectors 0; residualControl { T 1e-2; p 1e-2; U 1e-3; "(k|epsilon|omega)" 1e-3; } } Thank you. |
December 8, 2013, 10:53 |
Bernhard
Rep Power: 22 |
Add
pRefCell 0; pRefValue 0; You are changing more things, as you are trying to solve using a SIMPLE algorithm (apparently), which looks up different subdictionaries. |
The turbulent swirling flow test case - Dellenback | dogan | Main CFD Forum | 0 | February 27, 2013 09:10 |
cavity case with different mesh | masterfgee | OpenFOAM | 1 | July 21, 2010 12:53 |
Interfoam Droplet under shear test case | adona058 | OpenFOAM Running, Solving & CFD | 3 | May 3, 2010 19:46 |
looking for a test case, DES, Supersonic flow | kaarthik | Main CFD Forum | 0 | June 7, 2007 06:49 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 13:24 |
