thermal couple boundary condition between porous and fluid regions
Like Tree2Likes
  • 1 Post By atoof
  • 1 Post By styx
Old   November 26, 2013, 03:39
Default thermal couple boundary condition between porous and fluid regions
Hossein
atoof is on a distinguished road
Send a message via Yahoo to atoof
Dears,
I intend to simulate a reacting flow in a porous media. Geometry of that problem as attached includes three regions where the porous media stands between two fluid regions. So I'm trying to add solid temperature equation to rhoPorousSimpleFoam to capture the porous matrix temperature in a reacting flow in porous media.
I have a problem with temperature boundary condition for the porous region. That BC likes this:
Ks grad(Ts) = h (Ts - Tf)
where Ks and h are known constants and Ts and Tf are solid and fluid temperatures, respectively.
I do not know how to implement such BC for a region that the flow can pass through it. I've read most of posts about conjugate heat transfer, but in all of them there were Impermeable solid region beside a fluid region and the flow could not pass along a porous media.
I would be very helpful if someone can suggest a solution.
Hossein
kanchajiaxie likes this.
atoof is offline   Reply With Quote
Old   December 18, 2013, 10:20
ande
styx is on a distinguished road
I have a similar problem. I also want to simulate the heat transfer between porous media and a fluid. The porous media should heat up the airflow and thereby ist should cool down. I tried to simulate this with chtMultiRegionSimpleFoam and fvOptions "interRegionExplicitPorositySource" and "interRegionHeatTransferModel", without success.
fumiya likes this.
styx is offline   Reply With Quote
Old   June 7, 2017, 20:44
alberto
dewey is on a distinguished road
Hi, could you tell me if you could do your simulation? i am workin with porous media and heat transfer, i did a simulation with buoyantSimplefoam and include the porosity with fvOptions. Is this right?
dewey is offline   Reply With Quote
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
boundary condition between porous and fluid zones Mansureh FLUENT 5 June 5, 2011 10:31
Porous media Interfacial boundary condition Amadou Sowe FLUENT 0 March 14, 2006 16:55
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
porous plain media interfacial boundary condition. rockida FLUENT 0 June 10, 2004 07:33
