Adding two Energy Equations to Porous Solver
Like Tree1Likes
  • 1 Post By Cyp
Old   October 29, 2013, 11:38
Default Adding two Energy Equations to Porous Solver
Faraj
Filankes is on a distinguished road
Hello everyone,
I want to simulate porous media with solid heat transfer.
I am going to add "addTwoEquationsEnthalpy" to hEqn.h
fvScalarMatrix hEqn
fvm::div(phi, h)
- fvm::Sp(fvc::div(phi), h)
- fvm::laplacian(turbulence->alphaEff(), h)
- fvc::div(phi, 0.5*magSqr(U), "div(phi,K)")
pZones.addTwoEquationsEnthalpySource(thermo, gamma, ts, hEqn);
hEqn.relax();
hEqn.solve();
thermo.correct();
Apart from it I should add tsEqn.h equation somewhere in solver folder "I guess so"
fvScalarMatrix tsEqn
-fvm::laplacian(kappa,ts)
pZones.addTwoEquationsTsSource(thermo, gamma, ts, tsEqn);
tsEqn.relax();
tsEqn.solve();}
Here "kappa" is convection constant and "ts" is temperature of solid.
I just don't know the procedure of adding this equation to the solver. If you could help me, that would be very nice. Thank you.
Filankes is offline   Reply With Quote
Old   October 30, 2013, 17:19
Cyp
Cyprien
Cyp is on a distinguished road
Is your simulation domain only a porous medium ? In that case, I suggest you to program your own solver. You will get what you are doing under control !
Here is a full tutorial to program a 2 temperatures heat transfer solver in porous media (from slide #60)
https://www.imft.fr/IMG/pdf/INITIATI...OME_1v3-05.pdf
Everything is in French (I prepare an english version.. but not for now) but there is all the snippets and you could easily understand what you have to code.
Regards,
Cyp
Bahram likes this.
Cyp is offline   Reply With Quote
Old   December 3, 2013, 06:20
Faraj
This is perfrect, Thank you very much. I already started to modification of the solvers.
My simulation domain is partially (20 %) porous medium.
Energy based steady state solver. atareen64 OpenFOAM Running, Solving & CFD 6 May 6, 2011 12:21
Maths problem when deriving conservation of energy equations. Demonwolf Main CFD Forum 1 June 15, 2009 15:21
free " ordinary differential equations solver" ztdep Main CFD Forum 2 March 21, 2006 02:58
Porous media convection UDS equations cp FLUENT 1 September 19, 2003 20:53
Navier-stokes equations and iterative solver?? wuliang Main CFD Forum 2 January 13, 2003 23:28
