Questions on shallowWaterFoam
Like Tree5Likes
  • 1 Post By loic_d
  • 4 Post By randolph
Old   October 16, 2013, 06:25
Default Questions on shallowWaterFoam
haze_1986 is on a distinguished road
Hi all, just would like to verify certain parts of the code:
http://www.tfd.chalmers.se/~hani/kur...vistReport.pdf
From the tutorial it was mentioned that h is the mean surface height and h0 is the deviation from the mean surface height? Should it be the other way round? In the code h is used in most of the momentum equations and theoretically this should be the mean plus the deviation.
fvVectorMatrix hUEqn
fvm::ddt(hU)
+ fvm::div(phiv, hU)
On the other hand, in the mometum predictor, h+h0 is used in the code. Theoretically, we need to use the deviation from the mean inside the grad, which based on the tutorial definition should be h0.
solve(hUEqn + (F ^ hU) == -magg*h*fvc::grad(h + h0));
Is there something I am missing here?
haze_1986 is offline   Reply With Quote
Old   May 6, 2015, 16:13
Loïc Dagnas
loic_d is on a distinguished road
Hi all,
I faced this problem last month.
This tutorial contains a lot of errors, h is the water height and h0 the bed height.
randolph likes this.
loic_d is offline   Reply With Quote
Old   November 1, 2019, 12:24
RoderickZ is on a distinguished road
Originally Posted by loic_d View Post
Hi all,
With water height (h) you refer to the elevation of the free surface relative to the geoid and h_0 is the bathymetry ?
or h the height from topography to free surface?
(https://users.oden.utexas.edu/~arbog.../dawson_v2.pdf)
RoderickZ is offline   Reply With Quote
Old   November 1, 2019, 13:46
Reviewer #2
randolph is on a distinguished road
In OpenFOAM, your coordinate origin should be defined somewhere below the bottom floor. h0 is your bottom elevation (vertical distance from the bottom to your coordinate origin). h is your water column depth (from your water surface to the top of your bottom floor). And the htotal is a dummy; as defined as htotal = h0+h, which is your total water surface elevation (water surface to your origin).
Further information can be found at: A high-order arbitrarily unstructured finite-volume model of the global atmosphere: Tests solving the shallow-water equations.
Thanks,
Rdf
randolph is offline   Reply With Quote
Old   May 4, 2020, 14:54
Default shallowFoam Example
TomS's Avatar
TomS is on a distinguished road
You will find an example of a shallowFoam application and details of verification and set-up here:
https://www.mts-cfd.com/ballater
Tom
TomS is offline   Reply With Quote
New User, Basic Questions (Yacht Design) nyskiffie STAR-CCM+ 0 March 13, 2013 17:01
possible interview questions atturh Main CFD Forum 1 February 21, 2012 09:53
NACA0012 Validation Case Questions ozzythewise Main CFD Forum 3 August 3, 2010 15:39
novice star ccm+ questions apc3161 STAR-CCM+ 2 August 25, 2009 11:15
turbulence modeling questions llowen Main CFD Forum 3 September 11, 1998 05:24
