interFoam's UEqn.
Like Tree2Likes
  • 1 Post By eysteinn
  • 1 Post By akidess
Old   September 10, 2013, 10:03
Default interFoam's UEqn.
Dongyue Li
sharonyue is on a distinguished road
Hi guys,
In thies UEqn we have:
solve
            UEqn
            fvc::reconstruct
                    fvc::interpolate(interface.sigmaK())*fvc::snGrad(alpha1)
                  - ghf*fvc::snGrad(rho)
                  - fvc::snGrad(p_rgh)
                ) * mesh.magSf()
Can I code it like this:
solve
            UEqn
                    interface.sigmaK()*fvc::grad(alpha1)
                  - ghf*fvc::grad(rho)
                  - fvc::grad(p_rgh)
Actually Im confused about the difference with the grad() and sngrad(). Any ideas?
sharonyue is offline   Reply With Quote
Old   September 10, 2013, 13:34
Eysteinn Helgason
eysteinn is on a distinguished road
Originally Posted by sharonyue View Post
Hi guys,
solve
            UEqn
            fvc::reconstruct
                ) * mesh.magSf()
solve
            UEqn
                  - fvc::grad(p_rgh)
grad() is the "normal" gradient calculated in the cell center while sngrad()
is the surface normal gradient that is defined on the face of the cell.
(Which explains why interface.sigmaK is interpolated from the cell center
to the face before performing the multiplication.)
fvc::reconstruct reconstructs the cell centered values from the face values.
Hope this helps
/Eysteinn
sharonyue likes this.
eysteinn is offline   Reply With Quote
Old   September 12, 2013, 23:10
Dongyue Li
Hope this helps
/Eysteinn
I tried to revise it into this:
if (pimple.momentumPredictor())
        solve
            UEqn
                  - gh*fvc::grad(rho)
                  - fvc::grad(p_rgh)
Then wmake successfully, Then I made a test on dambreak, I get the totally same result(see the log). So it works, but I dont know why Weller make it interpolating U then reconstruct it, it would be easy in my way.
Old   September 13, 2013, 07:11
Eysteinn Helgason
I have not used this solver, but my (wild) guess is that this is used to resolve some
convergence problems with the momentum equation.
When you ran the cavity case was the momentumPredictor set to yes
under pimple in the system/fvSolution?
/Eysteinn
Old   September 15, 2013, 21:17
Dongyue Li
/Eysteinn
Sorry, I did not, so the log is absolutely the same. While I tried to set it to yes, but the result is almost the same. not differ much.
Old   July 9, 2016, 06:43
Hao Chen
hchen is on a distinguished road
Hi
I am also curious about it. Anybody has a comment on this issue?
hchen is offline   Reply With Quote
Old   July 11, 2016, 03:36
akidess's Avatar
Anton Kidess
Using cell centered values is not consistent and can lead to problems. I think you can find details in S. S. Deshpande, L. Anumolu, and M. F. Trujillo, Computational Science & Discovery 5, 014016+ (2012), ISSN 1749-4699, URL http://dx.doi.org/10.1088/1749-4699/5/1/014016. (which anyone working with interFoam should read).
Saturne_User likes this.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
A question about UEqn sonicFoam lfgmarc OpenFOAM Programming & Development 6 February 1, 2015 17:49
About UEqn in icoFoam. sharonyue OpenFOAM Programming & Development 11 July 3, 2013 00:44
Difference between UEqn in sonicFoam & Theory sasanghomi OpenFOAM Programming & Development 9 June 27, 2013 05:12
Adding an explicit source term in the UEqn() Anne Lincke OpenFOAM Running, Solving & CFD 0 June 25, 2013 13:19
Source term problem in UEqn of simpleFoam fisch OpenFOAM Programming & Development 1 June 17, 2011 11:57
