July 25, 2013, 05:41 |
Calculation of motion continuity error
Sasan Ghomi
Rep Power: 15 |
Hi Dear Foamers,
I am trying to understand calculating of motion continuity error. I think first line in below code is creating an object without any dimension and I don't understand the meaning of [d/dt ( Object ) ] . Also I couldn't understand what do meshPhi(U) do exactly . Code:
volScalarField motionContErr = fvc::ddt(dimensionedScalar("1", dimless, 1.0), mesh) - fvc::div(fvc::meshPhi(U)); I appreciate any help from you. Thanks and best regards, Sasan. |
March 11, 2016, 15:24 |
Dongyue Li
Rep Power: 18 |
My OpenFOAM algorithm website: http://dyfluid.com By far the largest Chinese CFD-based forum: http://www.cfd-china.com/category/6/openfoam We provide lots of clusters to Chinese customers, and we are considering to do business overseas: http://dyfluid.com/DMCmodel.html |
March 12, 2016, 17:15 |
Thomas Boucheres
Rep Power: 13 |
Sharonyue gives you good answer but maybe not so easy to understand if you are "new" to CFD discretization techniques If it is the case, maybe it is difficult to understand what means the time derivative of 1. Isn't it equalt to zero??? In fact, if you want to really understand the meshPhi(U) goal, you should read some courses on the topic "ALE technique" (for Arbitrary Lagrangian Eulerian) which allows the computation of flows on moving meshes. One difficulty in doing that is to respect a "hidden" conservation law which is called in the litterature the "GCL" (for Geometric Conservation Law). Roughly speaking, the time evolution of the mesh must be done in such a way that one respect a kind of compatibility condition( the so-called GCL) between the temporal evolution of the volume of a cell and the face flux resulting from the velocity associated with the mesh motion. This is precisely the meaning of the equation writtent by Sharonyue. |
Problem running perturbUCyl | sen.1986 | OpenFOAM | 17 | June 4, 2019 06:56 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 19:00 |
Undeclared Identifier Errof UDF | SteveGoat | Fluent UDF and Scheme Programming | 7 | October 15, 2014 08:11 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 08:24 |
c++ libraries and solver compiling | vaina74 | OpenFOAM Installation | 13 | February 3, 2012 18:43 |
