turbulent schmidt number with scalarTransportFoam
Like Tree6Likes
  • 6 Post By dgenekim
Old   July 25, 2013, 03:38
Default turbulent schmidt number with scalarTransportFoam
dongjin kim
dgenekim is on a distinguished road
Hi Foamers,
I need a solver which can deal with turbulent diffusivity instead of constant DT.
I have tried to modify the original scalarTransportFoam code as:
In createField.H, I added
Info<< "Reading field nut\n" << endl;
volScalarField nut
IOobject
"nut",
runTime.timeName(),
mesh,
IOobject::MUST_READ,
IOobject::AUTO_WRITE
mesh
and
Info<< "Reading diffusivity ScT\n" << endl;
dimensionedScalar ScT
transportProperties.lookup("ScT")
and modified the scalarTransportFoam.C as:
solve
fvm::ddt(T)
+ fvm::div(phi, T)
- fvm::laplacian(nut/ScT, T)
fvOptions(T)
The compiling was done without error message. However, when I ran a test simulation I got the error message as:
--> FOAM FATAL IO ERROR:
"ill defined primitiveEntry starting at keyword 'laplacian(nut' on line 37 and ending at line 60"
file: /home/dongjin/OpenFOAM/dongjin-2.2.1/practice/crossflowmixingchannel/scalarTransportFoam/system/fvSchemes at line 60.
From function primitiveEntry::readEntry(const dictionary&, Istream&)
in file lnInclude/IOerror.C at line 132.
FOAM exiting
Before running a simulation, I copied the 'nut' file from the previous simpleFoam simulation under the '0' folder, and modified the transportProperties and fvScheme files as:
laplacianSchemes
default none;
laplacian(nut/ScT,T) Gauss linear corrected;
and
ScT ScT [ 0 0 0 0 0 0 0 ] 0.15;
Please reply me why I got the above mentioned error?
dgenekim is offline   Reply With Quote
Old   July 25, 2013, 03:54
dongjin kim
I could make the run further by changing fvScheme as:
from
to
laplacian(nut|ScT,T) Gauss linear corrected;
but now I got:
file: /home/dongjin/OpenFOAM/dongjin-2.2.1/practice/crossflowmixingchannel/scalarTransportFoam/0/nut.boundaryField.upperWall from line 2906 to line 2910.
From function fvPatchField<Type>::New(const fvPatch&, const DimensionedField<Type, volMesh>&, const dictionary&)
in file /opt/openfoam221/src/finiteVolume/lnInclude/fvPatchFieldNew.C at line 136.
FOAM exiting
Any idea?
Old   July 25, 2013, 04:14
dongjin kim
In nut file, line number from 2906 to 2910 contains:
2903 }
2904 upperWall
2905 {
2906 type nutkWallFunction;
2907 Cmu 0.09;
2908 kappa 0.41;
2909 E 9.8;
2910 value nonuniform List<scalar>
Old   July 25, 2013, 04:49
dongjin kim
I just make the run successful by simply modifying nut file as:
from
Cmu 0.09;
kappa 0.41;
E 9.8;
to
type calculated;
and by fixing fvScheme file as:
from
to
laplacian((nut|ScT),T) Gauss linear corrected;
I will leave this posting for other users information ^^
Old   November 26, 2020, 11:07
MENOFYIA
ibrahim hagali is on a distinguished road
I have a question please, How the SCT distribution gonna be calculated, you have not included this step in the above code?
ibrahim hagali is offline   Reply With Quote
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
Turbulent Schmidt Number John FLUENT 8 June 1, 2015 06:04
decomposePar pointfield flying OpenFOAM Running, Solving & CFD 28 December 30, 2013 16:05
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 10:01
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
