Sub-iterations for transport equation in drift-flux |
Siemen Dasselaar
Rep Power: 12 ![]() |
Hi all,
I am currently working on a drift-flux (or algebraic-slip) model to simulate the sedimentation of sand in water. After solving the transport equation for sand, I use the packingLimiter.H like in twoPhaseEulerFoam in order to maintain the maximum packing concentration of sand (say 0.6). If I take the time-step dt too large, a certain computational cell can be filled with an amount of sand such that the packingLimiter cannot reduce the sand to the maximum packing concentration. If the packing concentration exceeds a value of 1.0, the solving process is aborted by the solver. I am wondering if I could decrease the timestep dt only for solving the transport equation. Say, 10 sub-iterations on the transport equation are chosen with for each sub-iteration the timestep 0.1*dt. Each time the packingLimiter is applied after a sub-iteration. Does anybody know how I can call the magnitude of the timestep in the source code, such that I can modify it? Thanks in advance! |
Klas J
Rep Power: 14 ![]() |
Hi Siemen,
For the twoPhaseEulerFoam solver the time step is set from the include of: Code:
#include "setDeltaT.H" For subiterations, perhaps you would find some interest in: http://www.cfd-online.com/Forums/ope...ime-loops.html. I guess you would like to use subCycles to achieve subiterations for some part of the code. Have a look at e.g the alphaEqn.H in twoPhaseEulerFoam. There a subCycle is used to solve the dispersed phase continuity equation. Inside the loop the deltaT is split according to how many sub-iterations you have specified. The code, subCycle.H and subCycleTime.H, will help you with the time step splitting. Best regards, Klas |
Siemen Dasselaar
Thanks Klas!
I will have a look at it. I think that is indeed what I searched for. Regards, Siemen |
drift-flux, sub-iterations, transport equation |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
Interfoam blows on parallel run | danvica | OpenFOAM Running, Solving & CFD | 16 | December 22, 2012 02:09 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 11:16 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
