Check if a file is a valid foamFile
Like Tree2Likes
  • 2 Post By wyldckat
Old   June 17, 2013, 11:10
Default Check if a file is a valid foamFile
Marcel Vonlanthen
Sylv is on a distinguished road
Dear Foamer,
Is there a function/method to check if a file is a well formatted foamFile? Namely, if it start by a valid header? I'm looking for something, which return a bool, then I can handle the different cases...
For example:
example 1: well formatted
FoamFile
    version     2.0;
    format      ascii;
    class       vectorField;
    object      values;
example 2: well formatted
// blah blah blah
FoamFile
    version     2.0;
    format      ascii;
    class       vectorField;
    object      values;
example 3: badly formatted:
//blah blah blah
324
456.8
5.7
34
Sylv is offline   Reply With Quote
Old   June 17, 2013, 17:43
Retired Super Moderator
Bruno Santos
Greetings Marcel,
In OpenFOAM's source code applications folder, you should be able to find several examples like the following, which can be seen online here:
https://github.com/OpenFOAM/OpenFOAM...ryLayer.C#L167
        // Turbulence omega
        IOobject omegaHeader
            "omega",
            runTime.timeName(),
            mesh,
            IOobject::MUST_READ,
            IOobject::NO_WRITE,
            false
        if (omegaHeader.headerOk())
            volScalarField omega(omegaHeader, mesh);
            omega =
                epsilon
                   Cmu*k+dimensionedScalar("VSMALL", k.dimensions(), VSMALL)
            omega.correctBoundaryConditions();
            Info<< "Writing omega\n" << endl;
            omega.write();
As you can see, it first only loads up the header mechanism, to check if the header is OK. Only then does it finally load the whole field file and process it.
Best regards,
Bruno
Tobi and Sylv like this.
Old   June 18, 2013, 05:31
Marcel Vonlanthen
Hello Bruno,
Thank you for the tip, it works!
Regards,
Marcel
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
[swak4Foam] swak4Foam-groovyBC build problem zxj160 OpenFOAM Community Contributions 18 July 30, 2013 13:14
which tutorial can find that include Riemann boundary condition? immortality OpenFOAM Running, Solving & CFD 12 May 3, 2013 18:21
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 10:57
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
