Read a vector list with IFstream and create IOobject from it
Like Tree1Likes
  • 1 Post By abiy
Old   June 14, 2013, 10:30
Default Read a vector list with IFstream and create IOobject from it
Marcel Vonlanthen
Sylv is on a distinguished road
Dear foamer,
I want to use some cutting planes from a source case (generate by the runtime sampling tool) to feed the inlet of a target case. To do so, I use the BC timeVaryingMappedFixedValue at the inlet of my traget case.
Unfortunately, the foamFiles generated by the sampling tool have no header, thus I cannot read them directly with timeVaryingMappedFixedValue (TVMFV). So I decided to modify this BC.
for example, TVMFV reads U values from the file U with an IOobject (IOobject needs header):
IOField<point> samplePoints
            IOobject
                "points",
                this->db().time().constant(),
                "boundaryData"/this->patch().name(),
                this->db(),
                IOobject::MUST_READ,
                IOobject::AUTO_WRITE,
                false
I can read the U from the sampling tool with IFstream (does not need header):
vectorField readU;
fileName caseDir = "path/to/my/Ufile"
IFstream dataStream(caseDir/"U");
dataStream >> readU;
How can I reconstruct the IOobject in TVMFV with my vectorField "readU"? My question is similar to this post http://www.cfd-online.com/Forums/ope...-foamfile.html, but I still don't understand how to do it...
Sylv is offline   Reply With Quote
Old   October 9, 2017, 16:25
Abiy Melaku
abiy is on a distinguished road
Hello Marcel!
I am replying late because it took me 5 years to figure out the answer .
In case if you are still looking for the answer, you can create IOField from already existing field as follows.
IOField<vector> readUIO
            IOobject
                "readU",
                this->db(),
                false
            readU
Hope this will help!
abiy is offline   Reply With Quote
