Jim Knopf
Rep Power: 15 ![]() |
Hello Everyone,
i got a problem that i don't understand. What I want: A custom BC derived from fixedGradientFvPatchField What I tried: Copy the original source code an replace fixedGradientFvPatchField with hTCFvPatchField in the filenames and in the files. Added a Make directory with files: Code:
hTCFvPatchField.C LIB = $(FOAM_USER_LIBBIN)/libmyBCs Code:
EXE_INC = \ -I$(FOAM_SRC)/finiteVolume/lnInclude LIB_LIBS = Code:
hTCFvPatchField.C:37:1: error: redefinition of 'Foam::hTCFvPatchField<Type>::hTCFvPatchField(const Foam::fvPatch&, const Foam::DimensionedField<Type, Foam::volMesh>&)' hTCFvPatchField.C:37:1: error: 'Foam::hTCFvPatchField<Type>::hTCFvPatchField(const Foam::fvPatch&, const Foam::DimensionedField<Type, Foam::volMesh>&)' previously declared here hTCFvPatchField.C:49:1: error: redefinition of 'Foam::hTCFvPatchField<Type>::hTCFvPatchField(const Foam::hTCFvPatchField<Type>&, const Foam::fvPatch&, const Foam::DimensionedField<Type, Foam::volMesh>&, const Foam::fvPatchFieldMapper&)' What did I do wrong? I tried the same workflow with the original code and got the same result ?!? I would be glad abount any idea. Greets Jim |
Jim Knopf
Although double posting should be no godd style, here is the answer I found:
in Make/files is has to be Code:
htcFvPatchFields.C LIB = $(FOAM_USER_LIBBIN)/libmyBCs It does just include the definition file and does some kinde of object registration, but it does not do a forward declaration. Greets, Jim Last edited by JimKnopf; March 21, 2013 at 15:51. |
Daniel P. Combest
Rep Power: 0 ![]() ![]() |
Just a tip on derived boundary conditions. If it is going to be derived from a basic type, then start with something else other than the basic type. By this i mean, go to an already derived BC from the type you want....and start from there. This will be much less painless as you will deal less with the template and minimize the amount of time you bang your head on the table in frustration
![]() #protip |
Jim Knopf
The head banging is definitly your point. but for me, I don't like to do what the software "wants" me to do, I like to do with the Software what I want.
![]() Templates are not the magic that made the problem, it was more the point that there is a "NoRepository" Flag in the class.H file, which included the .C file and therefore produced a preprocessor loop. What I'm wondering is, why is it done the way it is done, to me it makes no sense yet. As far as I can see, the inventors of OpenFoam included some kind of sens in every piece of their code. ![]() ![]() Greets Jim |
Periodic Boundary Condition | C.C | Main CFD Forum | 24 | November 6, 2016 08:02 |
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 05:57 |
Opening Boundary Condition | andreachan | Main CFD Forum | 11 | March 19, 2013 16:46 |
Setting outlet Pressure boundary condition using CAFFA code | Mukund Pondkule | Main CFD Forum | 0 | March 16, 2011 03:23 |
How exactly the "pressure outlet" bdry condition compute properties on the boundary? | yating9901 | FLUENT | 3 | June 28, 2010 12:26 |
