How to access nuSgs from pisoFoam.C
Like Tree1Likes
  • 1 Post By Lieven
Old   January 25, 2013, 12:45
Default How to access nuSgs from pisoFoam.C
Marcus Letzel
letzel is on a distinguished road
Dear Foamers,
my task is to add a passive scalar transport equation to pisoFoam.C. Since this is to be run as LES, the subgrid-scale scalar flux is also required, for which I need nuSgs. I would like to know how to access nuSgs from the modified pisoFoam.C.
Compilation of pisoModified.C
        turbulence->correct();
        solve
            fvm::ddt(s)
          + fvm::div(phi, s)
          - fvm::laplacian(nuSgs(), s)
          sSource
        runTime.write();
gives the error message
pisoModified.C:135: error: ´nuSgs´ was not declared in this scope
I have tried a recommendation from 2009,
sgsModel->nuSgs()
but the error message then simply changes to
pisoModified.C:135: error: ´sgsModel´ was not declared in this scope
I would be grateful for any suggestions.
Marcus
letzel is offline   Reply With Quote
Old   January 25, 2013, 18:01
Lieven
Lieven will become famous soon enough
Use
turbulence->nuSgs()
Have a look at createFields.H and try to understand why this works.
If I were you, I would also include a Schmidt-number in the laplacian...
Cheers,
Lieven
Lieven is offline   Reply With Quote
Old   January 26, 2013, 10:44
Marcus Letzel
Thank you for your advice, Lieven.
Changing
nuSgs()
to
turbulence->nuSgs()
yields the compilation error
pisoModified.C:135: error: ‘class Foam::incompressible::turbulenceModel’ has no member named ‘nuSgs’
I have then checked the list of class members, and as far as I understand, it should be fine if I reference nuSgs() from the class LESModel as
LESModel->nuSgs()
so that my code works with any LESModel. This, however, yields the old error message again:
pisoModified.C:135: error: ´LESModel´ was not declared in this scope
Where is my mistake?
Old   January 26, 2013, 11:50
Lieven
Sorry, my mistake. U should use
turbulence->nut()
which will return nuSgs() in case of an LESModel.
Cheers,
Lieven
sdharmar likes this.
Old   January 27, 2013, 15:15
Marcus Letzel
This works, thank you, Lieven.
Now, probably my final question in this thread, I would like to know how I could have deduced this information by myself. If you are aware of a relevant post or documentation that teaches users how to proceed themselves in such cases, please kindly let me know. Of course, in the end it is a matter of personal OpenFOAM experience.
Old   January 27, 2013, 15:42
Lieven
Well... it's probably a combination of experience and a lot of reading on this forum/pages found via Google/tutorials/...
e.g. I just saw for example that there is a similar discussion going on here:
http://www.cfd-online.com/Forums/ope...lent-flow.html
It will probably also help to read a bit about the principles of object oriented programming, and in particular about inheritance and it's implementation in C++ cause OF is simply filled with this.
The C++ Source Guide created by Doxygen (http://www.openfoam.org/docs/cpp/) is also a huge aid in understanding the OF source code structure so I advise you to try to familiarize yourself with it (e.g. try to find the solution I gave you using Doxygen).
Of course, if you still end up stuck, there is certainly no shame in posting something on this forum .
Cheers,
Lieven
large eddy simulation, nusgs, pisofoam, scalar transport
Getting access to mesh (fvMesh) via object registry Chris Lucas OpenFOAM Programming & Development 18 January 15, 2024 03:57
[DesignModeler] DesignModeler Scripting: How to get Full Command Access ANT ANSYS Meshing & Geometry 53 February 16, 2020 16:13
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 18:18
Error: access: unbound variable,HELP sudhakar FLUENT 0 January 16, 2007 00:21
Access Density Allan Walsh FLUENT 3 October 4, 2005 08:55
