How to access the members of a "volScalarField"?
Like Tree2Likes
  • 2 Post By kmooney
Old   November 5, 2012, 07:19
Default How to access the members of a "volScalarField"?
Nilesh
u396852 is on a distinguished road
I have to compare the individual values of a volScalarField. It gives error saying that operator (>) is not defined for volScalarField varible. How do I access the each member of the volScalarField varialbe. Also, there is function which calculates shearStress() and stores in volScalarField. How to access the each member of that function?
u396852 is offline   Reply With Quote
Old   November 5, 2012, 17:59
kmooney's Avatar
Kyle Mooney
kmooney is on a distinguished road
You can access the entries of a volScalarField as such:
volScalarField myVSF;
scalarField intVSF = myVSF.internalField();
forAll(intVSF, cellI)
    intVSF[cellI] = whatYourAfter;
Note: A volScalarField has both internal and patch boundary values to access.
kmooney is offline   Reply With Quote
Old   November 9, 2012, 01:38
Nilesh
thank a lot kmooney for your reply it indeed works. thanks for the help.
Old   November 27, 2012, 07:35
Default access the values of volScalarField
Nilesh
Kmooney now with your suggestion i am able to define the intVSF but when i try to access the values of intVSF using the following code it gives errors. i am copying the error message at the end could you help understanding it
volScalarField shearstress = old_visc*strainRate(); /* old_visc is VSF and strainRate() is function which returns shear rate which is also VSF */
volScalarField shearrate = strainRate();
scalarField intVSF = shearstress.internalField();
scalarField intVSF1 = shearrate.internalField();
if ( current_time.value() < 0.0001)
return old_visc;
else
forAll(intVSF1, celll)
if (intVSF1[celll] < scalar(0.001))
return old_visc;
else
if (intVSF1[celll] > scalar(10000))
return old_visc;
else {
if (intVSF[celll] > scalar(temp)) /* temp is calculated in the code */
return nu0_ /nu0_ is defined in the code
else
return old_visc;
ERROR:
[compute-0-25.local:16834] *** An error occurred in MPI_Recv
[compute-0-25.local:16834] *** on communicator MPI_COMM_WORLD
[compute-0-25.local:16834] *** MPI_ERR_TRUNCATE: message truncated
[compute-0-25.local:16834] *** MPI_ERRORS_ARE_FATAL (goodbye)
[compute-0-3.local:01034] *** An error occurred in MPI_Recv
[compute-0-3.local:01034] *** on communicator MPI_COMM_WORLD
[compute-0-3.local:01034] *** MPI_ERR_TRUNCATE: message truncated
[compute-0-3.local:01034] *** MPI_ERRORS_ARE_FATAL (goodbye)
[compute-0-37.local:09710] *** An error occurred in MPI_Recv
[compute-0-37.local:09710] *** on communicator MPI_COMM_WORLD
[compute-0-37.local:09710] *** MPI_ERR_TRUNCATE: message truncated
[compute-0-37.local:09710] *** MPI_ERRORS_ARE_FATAL (goodbye)
[compute-0-23.local:00497] *** An error occurred in MPI_Recv
[compute-0-23.local:00497] *** on communicator MPI_COMM_WORLD
[compute-0-23.local:00497] *** MPI_ERR_TRUNCATE: message truncated
[compute-0-23.local:00497] *** MPI_ERRORS_ARE_FATAL (goodbye)
[compute-0-38.local:14813] [0,0,0] ORTE_ERROR_LOG: Timeout in file base/pls_base_orted_cmds.c at line 275
[compute-0-38.local:14813] [0,0,0] ORTE_ERROR_LOG: Timeout in file pls_rsh_module.c at line 1166
[compute-0-38.local:14813] [0,0,0] ORTE_ERROR_LOG: Timeout in file errmgr_hnp.c at line 90
mpirun noticed that job rank 0 with PID 14908 on node compute-0-38 exited on signal 15 (Terminated).
[compute-0-38.local:14813] [0,0,0] ORTE_ERROR_LOG: Timeout in file base/pls_base_orted_cmds.c at line 188
[compute-0-38.local:14813] [0,0,0] ORTE_ERROR_LOG: Timeout in file pls_rsh_module.c at line 1198
mpirun was unable to cleanly terminate the daemons for this job. Returned value Timeout instead of ORTE_SUCCESS.
0/: Permission denied.
size 0 is not equal to the given value of 11037
file: /home/u396852/OpenFOAM/u396852-1.5/paintCases/Ellisrun-0.001fix-time-step/processor0/2e-05/visco_old from line 18 to line 63.
From function Field<Type>::Field(const word& keyword, const dictionary& dict, const label s)
in file /share/apps/devel/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/Field.C at line 224.
FOAM exiting
Getting access to mesh (fvMesh) via object registry Chris Lucas OpenFOAM Programming & Development 18 January 15, 2024 03:57
[DesignModeler] DesignModeler Scripting: How to get Full Command Access ANT ANSYS Meshing & Geometry 53 February 16, 2020 16:13
Online libraries - with access to Journals momentum_waves Main CFD Forum 2 December 12, 2007 11:08
Error: access: unbound variable,HELP sudhakar FLUENT 0 January 16, 2007 00:21
Access Density Allan Walsh FLUENT 3 October 4, 2005 08:55
