if statement for volScalarField
Like Tree1Likes
  • 1 Post By akidess
Old   April 24, 2012, 04:37
Default if statement for volScalarField
Anja Miehe
AnjaMiehe is on a distinguished road
Hello Foamers,
I want to code an if condition for a volScalarField and I do get errors in compiling that the if statement does not work.
volScalarField T
volScalarField lambda
    IOobject
        "lambda",
        runTime.timeName(),
        mesh,
        IOobject::NO_READ,
        IOobject::AUTO_WRITE
    if (T>Tf)? 0 : pow((Tf-T)/(Tf-Tl),-0.35)
As the pow coding of a negative base with a negative exponent does not work, I need a workaround.
Any other coding idea is welcome as well.
Thanks in advance,
Regards,
Anja
AnjaMiehe is offline   Reply With Quote
Old   April 24, 2012, 06:00
akidess's Avatar
Anton Kidess
Use pos() and neg(): pos(T - Tf)* pow((Tf-T)/(Tf-Tl),-0.35)
AnjaMiehe likes this.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   April 24, 2012, 08:01
Anja Miehe
Hello akidess,
and thank you very much. That was the basic idea I needed. To make it work finally, I changed it a little bit using the magnitude:
 pos(Tf-T)*pow(mag(Tf-T)/(Tf-Tl),-0.35)
in order not to have a negative base.
Thanks again, Anja
if volscalarfield
Conditional statement over the entire mesh xisto OpenFOAM Programming & Development 6 November 24, 2010 13:13
If Statement Zaktatir CFX 5 June 19, 2010 07:09
Weak statement for Galerkin Method rugabug Main CFD Forum 0 March 26, 2010 20:19
Need help with statement in Gambit kbs FLUENT 16 May 9, 2008 09:15
marking statement in Latex mike Main CFD Forum 0 October 8, 2006 13:01
