Angle of attack input for simpleFoam analyses |
March 25, 2012, 22:48 |
Rep Power: 14 |
As a new user, I have a question on angle of attack input for airfoil analyses using simpleFoam. Is the angle of attack inputted during the process when the blockMeshDict is created (i.e. meshing process), or in the "U" velocity file when the freestreamValue is set for the velocity conditions for each of the boundaries. I would appreciate any guidance on this. |
March 26, 2012, 03:55 |
It doesn't make any difference. You can either set your domain at the angle of attack you want and then have the flow entering the inlet plane and going along one direction (say x) or you can have your domain at 0° and then set your flow to enter the domain at the angle you want, in this case you'll probably have to set 2 faces of the domain as an inlet. Of course, if you want to simulate many angles of attack the latter solution is the best because changing the angle of attack would be easier and, more important, your mesh wouldn't change as you change it.
March 26, 2012, 11:04 |
angle of attack question answered
Rep Power: 14 |
lovecraft22,
Thank-you for your help in clarifying the ways to set the angle of attack. Regards, |
December 23, 2013, 22:57 |
#4 | |
Albert Tong
Rep Power: 16 |
I understand the thread is quite old, but is there a way to set the b.c. with an angle of attack in OpenFOAM? Much would be appreciated for any answers on this? Merry Christmas!
Kind regards, Albert |
December 24, 2013, 11:40 |
Well, if you set your inlet as a velocity inlet, then you can set any angle of attack you want simply by imposing two components of the velocity vector…
So, if your flow is mainly in the x direction and the lift direction of your airfoil is in the z direction and you want to impose V as velocity with an angle of attack A, then you just need to set (V*cos(A),0,V*sin(A)) as your inlet velocity. |
December 25, 2013, 03:05 |
#6 | |
Albert Tong
Rep Power: 16 |
Thanks for your quick reply. Say the computational domain is a rectangular. If the inlet flow is in x direction, then side b.c. (two boundaries parallel to the inlet flow) could be set as symmteryPlane, and outlet velocity could be set as zeroGradient. But these b.c.s are no longer validated if the attack angle is non-zero. Then how to change the sides and outlet boundary conditions accordingly?
December 25, 2013, 12:13 |
You'll need two inlets + two outlets and you can keep the side walls as symmetry.
December 29, 2013, 22:15 |
#8 | |
Albert Tong
Rep Power: 16 |
Could you please elaborate on "two inlets + two outlets"? As there are only four boundaries, how do you set these boundaries + side symmetry?
December 30, 2013, 03:21 |
#9 |
Well, if your domain is rectangular then you have 6 walls which mean 6 boundary conditions to apply.
Now, let's consider a positive value of the angle of attack ( meaning your airfoil is probably generating lift) so that the flow is coming from under the airfoil. To this extent, the bottom wall and the front wall (the one facing the leading edge) will have to be set as inlets as the flow is entering your domain from there. The upper and back wall (the one facing the trailing edge) will have to be set as outlets as the flow is going out of there. The lateral walls instead can be set as symmetry/empty/or whatever you need them to be for you case. |
January 5, 2014, 22:59 |
#10 | |
Albert Tong
Rep Power: 16 |
Many thanks for your answers and patience. Now, it works pretty well with freesteam b.c. condition by two inlets and two outlets. Great help.
March 21, 2018, 12:13 |
#11 |
alix cattermole
Rep Power: 9 |
I previously ran the a case where I modeled the flow around the full DTCHull and got accurate results. Now I am trying to model the flow around the hull at different drift angles by altering the direction of the inlet velocity. I tried changing the velocity internalField to (Vcos(x), Vsin(x), 0) and changing one side to an inlet patch and the other side to an outlet patch but I am getting errors Both sides were previously symmetryPlane faces. Is this method anywhere close to being correct? Any help would be appreciated. |
August 8, 2018, 12:59 |
#12 | |
Ontario
Rep Power: 8 |
airfoil analysis, angle of attack, input, simplefoam |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 06:50 |
introducing angle of attack on ICEMCFD HEXA | icem beginner | CFX | 2 | December 24, 2008 12:00 |
introducing angle of attack on ICEMCFD HEXA | icem beginner | Main CFD Forum | 3 | December 17, 2008 06:05 |
angle of attack with icem hexa | icem beginner | Main CFD Forum | 0 | December 5, 2008 17:54 |
angle of attack | kiran | FLUENT | 0 | September 10, 2004 09:18 |
