standard kEpsilon, kqRWallFunction and epsilonWallFunction (why should give value ?)
Like Tree4Likes
  • 1 Post By panda60
  • 2 Post By AlanR
  • 1 Post By Gerard
Old   December 9, 2009, 06:19
Default standard kEpsilon, kqRWallFunction and epsilonWallFunction (why should give value ?)
Jiang
panda60 is on a distinguished road
Dear foamers:
I have been confused by the k and epsilon wall boundary condition in tutorials/imcompressible/simpleFoam/pitzDaily/0.
It write like this:
upperWall
type kqRWallFunction;
value uniform 0.375;
upperWall
type epsilonWallFunction;
value uniform 14.855;
in general, standard k-epsilon model, in the wall using wall function, that means k can be got by solving k equation(using dk/dn=0 in the wall), then epsilon or velocity can be got through empirical formular.
But I don't understand the exact meaning of kqRWallFunction and epsilonWallFunction, why should give a value here. I want to know it is neglected automaticly when using kEpsilon model.
Or if I use zeroGradient for k and epsilon in the wall will be better ?
Thanks for your reply.
hayhari likes this.
panda60 is offline   Reply With Quote
Old   December 10, 2009, 00:09
Jiang
I have try, if use zeroGradient for k and epsilon in the wall, the result a little not good. why ?
I remember that in OpenFOAM-1.5 , just use zeroGradient for k and epsilon in the wall.
kqRWallFunction and epsilonWallFunction just begin to use in 1.6 version.
I am confused. If OpenFOAM use standard wall function for kEpsilon model ?
Old   December 10, 2009, 06:06
Claus Meister
idrama is on a distinguished road
Take a look at the file in your OpenFOAM dictionary:
OpenFOAM-1.6/src/turbulenceModels/incompressible/RAS/RASModel/RASModel.C
at line 148. Maby it can help you.
idrama is offline   Reply With Quote
Old   May 22, 2010, 08:29
Default input kqRWallFuntion meaning
Aldo Iannetti
aldo.iannetti is on a distinguished road
Can you please explane me the meaning of the input I have to give to (for exemple turbulent kinetic energy) near walls:
value uniform 0.001;
how to use k-epsilon without wall function (corresponding to Enhanced wall treatment in fluent)?
thanks
aldo.iannetti is offline   Reply With Quote
Old   September 30, 2010, 08:10
Default kqRWall Functions
CFD user
subhkirti is on a distinguished road
Hello Panda,
I am trying to use the same wall function but I am not able to understand what it stands for. Did you figure out the answer to the question you asked here?
My function is defined as below.
This is similar to Omega,
type omegaWallFunction;
Cmu 0.09;
kappa 0.41;
E 9.8;
beta1 0.075;
value uniform 3.5;
Where do I find all these coefficients? How does changing them has an impact on the overall solution.
I looked at the file name given above, but I didn't get it.
Thanks,
Subhkirti.
subhkirti is offline   Reply With Quote
Old   October 1, 2010, 03:45
Default Try Doxygen
Alan Russell
AlanR is on a distinguished road
You can search Doxygen to find where functions are defined. Here's the Doxygen definition of kqRWallFunction from Doxygen:
Detailed Description
template<class Type>
class Foam::incompressible::RASModels::kqRWallFunctionFv PatDetailed Description
class Foam::incompressible::RASModels::kqRWallFunctionFv PatchField< Type >
Boundary condition for turbulence k, Q, and R when using wall functions. Simply acts as a zero gradient condition.
Source files
kqRWallFunctionFvPatchField.H
kqRWallFunctionFvPatchField.C
Definition at line 50 of file kqRWallFunctionFvPatchField.H.
chField< Type >
Source files
Turbulence model standard coefficients are defined in source code. For example, look in /src/turbulenceModels/incompressible/RAS/kEpsilon/kEpsilon.C. If you want to change the coefficients, it's easy to do in the RASProperties file in /constant directory of your simulation. To modify K-Epsilon coefficients, insert the following lines after turbulence on:
kEpsilonCoeffs
Cmu x.x;
C1 y.y;
C2 z.z;
This will change the three listed coefficient values and leave the default values for the others.
Alan
fede32 and SHANRU like this.
AlanR is offline   Reply With Quote
Old   January 18, 2011, 06:55
Default meaning of the value of kqRWallFunction
jms
José
jms is on a distinguished road
Can anybody explain me which is the meaning of the "value uniform" one sets on the wallFunction for k?
wall
value uniform 0.00735;
Thank you for your help!
jms is offline   Reply With Quote
Old   January 20, 2011, 11:42
Gerard is on a distinguished road
Hi Jose,
I had the same question and got an answer here:
http://www.cfd-online.com/Forums/ope...lon-omega.html
The value specified with a wall function is kind of an initial guess.
Greetings
Gerard
P.S.: Sorry for the misspelling of you name, I am not used to the keys I use at this moment.
labyrinth01 likes this.
Gerard is offline   Reply With Quote
Old   August 12, 2017, 16:03
Default kqRWallFunction
Amir
albet is on a distinguished road
Hi Foamers,
I have a question about the standard wall function.
I read that at high Reynolds number in the closest cell to the wall we should calculate the k by this equation:
k= sqr (utau)/Cmu25
but I have seen that everywhere it is recommended to use
kqRWallFunction
that in fact gives the zeroGradient boundary condition.
Could anybody help me to understand this?
Regards,
Amir
albet is offline   Reply With Quote
