laplacian1%7cAUp is undefined in dictionary problem with icoFoam
Like Tree1Likes
  • 1 Post By zakifoam
Old   May 6, 2007, 05:05
Default Hi to all, I've this msg of e
Giuseppe Noviello
derath is on a distinguished road
Hi to all,
I've this msg of error with my case using icoFoam solver, which means? Someone can help me?
--> FOAM FATAL IO ERROR : keyword laplacian((1|A(U)),p) is undefined in diction ary "/home/giuseppe/OpenFOAM/giuseppe-1.4/run/tutorials/icoFoam/prova/system/fvS chemes::laplacianSchemes"
file: /home/giuseppe/OpenFOAM/giuseppe-1.4/run/tutorials/icoFoam/prova/system/fv Schemes::laplacianSchemes from line 44 to line 46.
From function dictionary::lookupEntry(const word& keyword) const
in file db/dictionary/dictionary.C at line 146.
So my fvSchemes is:
ddtSchemes
default Euler;
gradSchemes
default Gauss linear;
grad(p) Gauss linear;
divSchemes
default none;
div(phi,U) Gauss linear;
laplacianSchemes
default none;
laplacian(nu,U) Gauss linear corrected;
laplacian(1|A(U),p) Gauss linear corrected;
interpolationSchemes
default linear;
interpolate(HbyA) linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p;
Thanks in advantage
derath is offline   Reply With Quote
Old   May 6, 2007, 05:19
Default Is it likely that you have inc
Zaki Saldi
zakifoam is on a distinguished road
Is it likely that you have inconsistency in your laplacian term writing?
OF complains that it can't find laplacian((1|A(U)),p), since in your fvSchemes it is written as laplacian(1|A(U),p) (notice the difference in brackets).
Good luck.
jamestangx likes this.
zakifoam is offline   Reply With Quote
Old   September 4, 2012, 15:46
Wei Liu
mathslw is on a distinguished road
Originally Posted by derath View Post
Hi to all,
So my fvSchemes is:
ddtSchemes
default Euler;
gradSchemes
divSchemes
default none;
laplacianSchemes
default none;
default linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p;
Thanks in advantage
Hi derath,
Have you solved your problem?
I also have this problem recently!
Thanks!
Wei
mathslw is offline   Reply With Quote
Old   June 14, 2013, 07:24
hasan hasan hasan
hasanmas is on a distinguished road
how about use only the default:
laplacianSchemes
default Gauss linear corrected;
hasanmas is offline   Reply With Quote
Error OF15dev interDyMFoam keyword agglomerator is undefined in dictionary eberberovic OpenFOAM Running, Solving & CFD 6 July 29, 2019 12:54
InterDyMFoam in 15dev keyword agglomerator is undefined in dictionary eberberovic OpenFOAM Running, Solving & CFD 0 February 16, 2009 11:17
RadialModel is undefined in dictionary mahaputra OpenFOAM Running, Solving & CFD 1 February 9, 2009 01:16
Problem with icoFoam nadine OpenFOAM Running, Solving & CFD 1 August 28, 2008 05:49
Problem with IcoFoam in parallel skabilan OpenFOAM Running, Solving & CFD 12 April 1, 2008 06:55
