November 13, 2024, 19:39 |
Boudary conditions in dsmcfoamplus problem
Artem
Hello everyone!
I decided to calculate the free-molecular flow around bodies of rotation. I am using the dsmcfoamplus module in OpenFoam 2.4.0-MNF. As an example I use the calculation of the Orion capsule (https://github.com/Eliasfarah0/dsmcF...dule/tree/main). For my example I set the flow velocity to 7000 m/s, the temperature to 196 K and the same gas parameters as in the Orion example. As a result of the calculation, I want to obtain the pressure and temperature distribution over the surface of the streamlined body. BUT! In the example and in the articles, the boundariesDict initially sets the boundary condition DiffuseWall and the temperature at the body wall, although this is something that I do not know initially and want to find. It seems that the zeroGradient boundary condition should be used, but OpenFoam gives an error if I use it. Please help me how to correctly set the boundary condition on the body wall. The boudariesdict code is below, the model image is https://ibb.co/hHxTBn1. Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.4.0-MNF | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object boundariesDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // **************** // // PATCH BOUNDARIES // // **************** // dsmcPatchBoundaries ( boundary { patchBoundaryProperties { patchName inlet; } boundaryModel dsmcDeletionPatch; dsmcDeletionPatchProperties { allSpecies yes; } } boundary { patchBoundaryProperties { patchName outlet; } boundaryModel dsmcDeletionPatch; dsmcDeletionPatchProperties { allSpecies yes; } } boundary { patchBoundaryProperties { patchName top; } boundaryModel dsmcDeletionPatch; dsmcDeletionPatchProperties { allSpecies yes; } } boundary { patchBoundaryProperties { patchName bottom; } boundaryModel dsmcDeletionPatch; dsmcDeletionPatchProperties { allSpecies yes; } } boundary { patchBoundaryProperties { patchName ocm; } boundaryModel dsmcDiffuseWallPatch; dsmcDiffuseWallPatchProperties { velocity (0 0 0); temperature 196.605; // from Orion Aerodynamics for Hypersonic Free Molecular to Continuum Conditions } } ); // ****************** // // GENERAL BOUNDARIES // // ****************** // dsmcGeneralBoundaries ( boundary { generalBoundaryProperties { patchName inlet; } boundaryModel dsmcFreeStreamInflowPatch; dsmcFreeStreamInflowPatchProperties { typeIds (N2 O2 O); velocity (7000 0 0); translationalTemperature 196.605; rotationalTemperature 196.605; vibrationalTemperature 196.605; electronicTemperature 0; numberDensities { N2 8.892e18; O2 2.106e18; O 7.020e17; }; } } boundary { generalBoundaryProperties { patchName outlet; } boundaryModel dsmcFreeStreamInflowPatch; dsmcFreeStreamInflowPatchProperties { typeIds (N2 O2 O); velocity (7000 0 0); translationalTemperature 196.605; rotationalTemperature 196.605; vibrationalTemperature 196.605; electronicTemperature 0; numberDensities { N2 8.892e18; O2 2.106e18; O 7.020e17; }; } } boundary { generalBoundaryProperties { patchName top; } boundaryModel dsmcFreeStreamInflowPatch; dsmcFreeStreamInflowPatchProperties { typeIds (N2 O2 O); velocity (7000 0 0); translationalTemperature 196.605; rotationalTemperature 196.605; vibrationalTemperature 196.605; electronicTemperature 0; numberDensities { N2 8.892e18; O2 2.106e18; O 7.020e17; }; } } boundary { generalBoundaryProperties { patchName bottom; } boundaryModel dsmcFreeStreamInflowPatch; dsmcFreeStreamInflowPatchProperties { typeIds (N2 O2 O); velocity (7000 0 0); translationalTemperature 196.605; rotationalTemperature 196.605; vibrationalTemperature 196.605; electronicTemperature 0; numberDensities { N2 8.892e18; O2 2.106e18; O 7.020e17; }; } } ); // ***************** // // CYCLIC BOUNDARIES // // ***************** // dsmcCyclicBoundaries ( // EMPTY ); // ************************************************************************* // |
boundary condition, dsmcfoam+ |
Boundary conditions problem | pj6620 | FLOW-3D | 9 | June 4, 2014 06:15 |
Problem Boundary Conditions, forceCoeff | valerio galluzzi | OpenFOAM Pre-Processing | 9 | May 7, 2014 12:16 |
Problem in Cell Zone conditions for Species Transport model | CFDP | FLUENT | 3 | March 5, 2013 05:14 |
Problem with periodic boundary conditions | jm_ngs | FLUENT | 7 | April 27, 2012 03:32 |
Fluent boundary conditions problem | bobo | FLUENT | 2 | July 3, 2009 07:28 |
