May 23, 2024, 09:21 |
rho in simpleFoam
Rep Power: 2 |
Hi, everyone!
I'm new member in OpenFOAM, currently simulating a stationary incompressible flow in a Tesla valve (velocity value at the inlet wall, 0 kPa at the outlet). Question: I see that you can enter a constant/turbulence Proportions that changes the viscosity - but how can I enter the density value of the liquid? I found on the forum that you need to multiply the resulting pressure by the value. This is true? Please help me figure it out |
May 24, 2024, 11:46 |
Yann
Rep Power: 29 |
You don't need to define density in incompressible solvers in OpenFOAM. Incompressible solvers use kinematic pressure, which is indeed static pressure divided by density. https://doc.openfoam.com/2312/tools/...atic-pressure/ |
May 25, 2024, 11:57 |
Rep Power: 2 |
Thank for your answer!
Am I correct in understanding that I need to multiply the pressure result that I get when the algorithm has converged by the density value to get it in Pascals? Can you explain why this is so - after all, there is density in the momentum equation (https://openfoamwiki.net/index.php/SimpleFoam), which simpleFoam solves... Another question about the resulting pressure on the Inlet wall - I wrote in controlDict so that it would give me the result of the pressure in the middle of the rectangle (the middle of the Inlet wall) - to what extent is this approach correct? Can you suggest, perhaps there are more correct ways, perhaps taking into account the size and structure of the grid Below I have attached how I determined the points at which I want to find out the pressure (there are two of them, because I start the flow of liquid in two directions) functions { probes { type probes; libs (sampling); writeControl timeStep; writeInterval 1; fields ( p U ); probeLocations ( (0 7.5e-05 0) (-0.006255624 7.5e-05 -0.00221) ); } } |
May 27, 2024, 06:28 |
#4 | ||
Yann
Rep Power: 29 |
There is no density solved anywhere in simpleFoam, you can have a look on these threads for more details: In what unit is pressure measured on OpenFOAM? Pressure units in incompressible solvers Quote:
liquid, pressure, simplefoam |
Converging Diverging Nozzle with dbnsTurbFoam | Saleh Abuhanieh | OpenFOAM Running, Solving & CFD | 4 | December 13, 2019 11:26 |
rho and rhoFinal in fvSolution and others | NewKid | OpenFOAM Running, Solving & CFD | 3 | July 15, 2019 10:36 |
rSF: p divergence in combustor (wt negative value) | zonda | OpenFOAM Pre-Processing | 4 | April 10, 2018 07:59 |
what does this verbose error mean? | immortality | OpenFOAM Running, Solving & CFD | 1 | February 6, 2013 17:47 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 04:34 |
