April 27, 2024, 11:37 |
fvOptions / Volumetric heat source
Christoph Trier
Rep Power: 2 |
Hey guys,
I could use some help setting up my Volumetric heat source. I am trying to model a uniform volumetric thermal source in the fluid. For that, I am using fvOptions. I already wrote my option file and the solver also works; however, I get a warning "Source heatSource defined for field he but never used", and I can't find out why. I have tried different fvOptions. In both cases, I get the same error, and I can't find out why. I am using a solver named buoyantPimpleMhdFoam (combination to use MHD and Heat). Further down, I'll post the EEqn.H. Thanks, Christoph first one Code:
FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvOptions; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // options { heatSource { type scalarSemiImplicitSource; active true; selectionMode all; volumeMode specific; sources { he (19.4487 0); } } } Code:
HeatSource { type scalarSemiImplicitSource; active true; selectionMode all; scalarSemiImplicitSourceCoeffs { volumeMode absolute; //alt. specific selectionMode all; injectionRateSuSp { he (20 0); } } } Code:
{ volScalarField& he = thermo.he(); fvScalarMatrix EEqn ( fvm::ddt(rho, he) + fvm::div(phi, he) + fvc::ddt(rho, K) + fvc::div(phi, K) + ( he.name() == "e" ? fvc::div ( fvc::absolute(phi/fvc::interpolate(rho), U), p, "div(phiv,p)" ) : -dpdt ) - fvm::laplacian(turbulence->alphaEff(), he) == rho*(U&g) + radiation->Sh(thermo, he) + fvOptions(rho, he) ); EEqn.relax(); fvOptions.constrain(EEqn); EEqn.solve(); fvOptions.correct(he); thermo.correct(); radiation->correct(); } PIMPLE: iteration 1 --> FOAM Warning : From virtual void Foam::fv:ption::checkApplied() const in file cfdTools/general/fvOptions/fvOption.C at line 137 Source heatSource defined for field he but never used |
April 28, 2024, 03:57 |
Yann
Rep Power: 27 |
Hello Christoph,
Here: Code:
he (19.4487 0); If you are using enthalpy it should be h, if you are using internal energy it should be e. In the code the variable is named he because it can be both, but the simulation actually solves for h or e depending on the case settings, and your source must be defined for the variable which is solved. I hope this will solve your problem. Yann |
October 16, 2024, 06:18 |
Adding a temperature dependent heat source term
Arunkl
Rep Power: 2 |
options { energySource { type scalarSemiImplicitSource; selectionMode cellSet; cellSet ignition; volumeMode specific; sources { h (2e7 0); // kg/m/s^3 } // Temperature-dependent behavior code #{ // Get the mean temperature from the temperature field const scalar T_mean = T.mean(); // Assuming T is the temperature field variable // Check if T_mean exceeds 250 °C if (T_mean >= 250 + 273.15) // Convert 250 °C to Kelvin { return 0; // Turn off the heat source if T_mean is 250 °C or higher } else { // Return the source value only if the temperature is below 250 °C return h; // Return the defined source value } #}; } } |
heatsource fvoptions |
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 | ordinary | OpenFOAM Installation | 19 | September 3, 2019 18:13 |
Unsteady problem with volumetric heat source | Jonathan94 | STAR-CCM+ | 1 | July 21, 2018 02:26 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 01:41 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 10:57 |
