[FrozenFlow] - thermoFoam
Like Tree2Likes
  • 2 Post By DashaSh
Old   October 4, 2023, 09:22
Default [FrozenFlow] - thermoFoam
Dasha
DashaSh is on a distinguished road
Dear All,
I need help getting up to date information about how OpenFoam 11 works.
I want to make a case with frozen flow and heat transfer. I did a little research and see that there used to be a “thermoFoam” solver that performed such function. When I try to find up-to-date information on how it works now, I can't find anything. Could someone send me documentation or a tutorial on how to solve problems with freezing of the flow now?
I have seen examples that freezing the flow is now(? not sure) added to fvSolution, but I don’t fully understand how it works and what the boundary conditions for velocity should be.
SIMPLE
    frozenFlow		yes;
I would be VERY grateful to you!
DashaSh is offline   Reply With Quote
Old   December 11, 2023, 09:54
Marius
Muerio is on a distinguished road
Hi Dasha,
I just started looking into this for OpenFoam 11 after using frozenFlow in version 8 a while ago.
As far as I can tell the keyword frozenFlow is missing in version 11.
Did you make any progress?
Muerio is offline   Reply With Quote
Old   December 12, 2023, 05:40
Dasha
Hi Marius!
Now, instead of the keyword 'frozenFlow,' the following is used:
    flow off;
    momentumPredictor off;
This needs to be added to fvSolution
armin69me and Muerio like this.
frozen flow, frozenfoam, thermofoam
thermoFoam vs scalarTransportFoam? granzer OpenFOAM Running, Solving & CFD 2 September 4, 2021 03:01
thermoFoam tutorial/example case shach934 OpenFOAM 2 October 2, 2019 13:24
Styrofoam Insulation Pakistan | Thermofoam Best Styrofoam Insulation in Pakistan thermofoam Mesh Generation & Pre-Processing 0 September 1, 2016 08:58
Using thermoFOAM over porousSimpleFoam simulation styleo86 OpenFOAM Running, Solving & CFD 1 February 15, 2016 21:03
