Mukul Chandra
Rep Power: 3 ![]() |
Could not load "dynamicCode/platforms/linux64GccDPInt32Opt/lib/libcodeStream_124637ec1044e3706f08a6b9fff6f2dacd9f 4cba.so" , this is the error i am getting while running the simulation. Please help.
#3 | |
Mark Olesen
Rep Power: 40 ![]() ![]() |
Are you certain that this is an error message and not just a warning? With dynamic code compilation it will first attempt to load a library corresponding to the SHA1 of the source code contents (and context). If this fails, it should normally go off and compile the code and then try again. If this doesn't success it could be that you are missing make, wmake src/OpenFOAM or something else on that particular node. You'll need to search a bit more. |
#4 | |
Mark Olesen
None of this will help since the message (or error) is coming from the dynamic code compilation and loading. The load library routine and underlying dlopen within OpenFOAM should already be receiving the fully resolved path to load. Fiddling with any '-L' option will do absolutely nothing since the solver is already running and loaded - you need to be injecting new symbol resolution dynamically, not at link time. |
Prom
I am also having a similar issue. I want to load a library from $FOAM_USER_LIBBIN so that I can use some of its functions in a codedFixedValue boundary condition. I am referencing the library in controlDict like this.
libs ( "$(FOAM_USER_LIBBIN)/libinterpolateTemperature.dylib" ); Code:
--> FOAM Warning : From void *Foam::dlLibraryTable::openLibrary(const Foam::fileName &, bool) in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 188 Could not load "$(FOAM_USER_LIBBIN)/libinterpolateTemperature.dylib" dlopen($(FOAM_USER_LIBBIN)/libinterpolateTemperature.dylib, 0x0009): tried: '/Volumes/OpenFOAM-v2306/platforms/darwin64ClangDPInt32Opt/lib/openmpi/libinterpolateTemperature.dylib' (no such file), '/Volumes/OpenFOAM-v2306/platforms/darwin64ClangDPInt32Opt/lib/libinterpolateTemperature.dylib' (no such file), '/Volumes/OpenFOAM-v2306/usr/opt/fftw/lib/libinterpolateTemperature.dylib' (no such file), '/Volumes/OpenFOAM-v2306/usr/opt/mpfr/lib/libinterpolateTemperature.dylib' (no such file), '/Volumes/OpenFOAM-v2306/usr/opt/gmp/lib/libinterpolateTemperature.dylib' (no such file), '/Volumes/OpenFOAM-v2306/usr/opt/cgal/lib/libinterpolateTemperature.dylib' (no such file), '/Volumes/OpenFOAM-v2306/usr/opt/boost/lib/libinterpolateTemperature.dylib' (no such file), '/Volumes/OpenFOAM-v2306/usr/opt/open-mpi/lib/libinterpolateTemperature.dylib' (no such file), '/Volumes/OpenFOAM-v2306/platforms/darwin64ClangDPInt32Opt/lib/dummy/libinterpolateTemperature.dylib' (no such file), '$(FOAM_USER_LIBBIN)/libinterpolateTemperature.dylib' (no such file), '/System/Volumes/Preboot/Cryptexes/OS$(FOAM_USER_LIBBIN)/libinterpolateTemperature.dylib' (no such file), '/usr/lib/$(FOAM_USER_LIBBIN)/libinterpolateTemperature.dylib' (no such file, not in dyld cache), '$(FOAM_USER_LIBBIN)/libinterpolateTemperature.dylib' (no such file) |
Rep Power: 6 ![]() |
I face similar problem, when I try to doing blockMesh, error appears like this:
--> FOAM FATAL IO ERROR: (openfoam-2312) Failed loading library "dynamicCode/_1046a627e95cf41b09672fbbb6b71d2c23de0441/platforms/linuxARM64GccDPInt32Opt/lib/libcodeStream_1046a627e95cf41b09672fbbb6b71d2c23de 0441.so" on some processors.Did you add all libraries to the 'libs' entry in system/controlDict? |
[OpenFOAM.com] Compiling Scotch library error | fedez91 | OpenFOAM Installation | 6 | March 2, 2022 23:25 |
Compile boundary condition as a new dynamic library | mohanphy | OpenFOAM Programming & Development | 22 | January 21, 2021 05:53 |
Pressure drop with filter dynamic loading | akaobi | STAR-CCM+ | 4 | March 30, 2018 10:08 |
Forcing a solver to use your custom library. | cdunn6754 | OpenFOAM Programming & Development | 0 | March 30, 2017 16:05 |
error in loading valve.c of dynamic mesh | Pavan | FLUENT | 4 | February 25, 2009 00:22 |
