Very stuck on an embarrassingly basic issue related to opening STL files |
Niall O'Neill
Rep Power: 3 ![]() |
Hello everyone,
I am having an extremely basic issue that I cannot figure out for the life of me. I've followed the motorbike SHM tutorial and am simply trying to replace the motorbike object with a cylinder. However, When I get to run the surface features dict I get the following: '--> FOAM FATAL ERROR: Cannot read "/home/niall/OpenFOAM/niall-10/run/CylinderFlowSHM/constant/geometry/Cylinder.stl" Furthermore, when I drag the STL file into paraView it won't even open in there, which makes no sense to me.' Does anyone have an idea what might be the cause of this? I exported the cylinder as an ascii stl file from solidworks. I suspect its something to do with the file itself, so what are some important considerations regarding STL files? I've attached the text file |
M
Rep Power: 12 ![]() |
I can display this file without any problem after changing the extension from .txt to .stl
If I remember correctly, solidworks exports the files per default as ".STL" and OpenFOAM wants them to be named ".stl". Maybe that is the issue? |
Niall O'Neill
That was indeed the issue! thank you very much
UDF issue | MASOUD | Fluent UDF and Scheme Programming | 14 | December 6, 2012 13:39 |
Problem opening backed up .hm files in HyperMesh | SivaMG | FLUENT | 0 | December 23, 2011 02:29 |
Meshing related issue in Flow EFD | appu | FloEFD, FloWorks & FloTHERM | 1 | May 22, 2011 08:27 |
Opening Vs outlet BCs and temporary wall issue | Sam | CFX | 0 | January 16, 2008 18:59 |
Issue with STL file in Flow3D | Rajiv Kothari | Main CFD Forum | 1 | July 24, 2006 12:53 |
