Inconsistent results for view factors between parallel and serial |
March 30, 2023, 08:59 |
Chris
Rep Power: 4 |
Hi everyone,
I have a chtMultiregionFoam case that I run in parallel. After Introducing a view factor radiation model I noticed that the results of Code:
faceAgglomerate -region air -dict system/air/viewFactorsDict viewFactorsGen -region air Code:
runApplication decomposePar -allRegions Code:
mpirun -np $1 faceAgglomerate -region air -parallel -dict system/air/viewFactorsDict mpirun -np $1 viewFactorsGen -region air -parallel This was ok for running the case but in order to use functionObjects for post-prosessing after run time was getting an error because finalAgglom files where missing from the reconstructed case. Now to get around this problem I do both ways of calculating view factors. But I noticed that the results I get in the log file for each method are different. Serial: Code:
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 9 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 9-b456138dc4bc Exec : viewFactorsGen -region air Date : Mar 30 2023 Time : 14:25:32 Host : "ct-System-Product-Name" PID : 178199 I/O : uncollated Case : /home/ct/OpenFOAM/ct-9/run/iSTORE/iSTORE_conical_radiation_2 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh air for time = 0 Creating single cell mesh... Created single cell mesh... Total number of coarse faces: 104 View factor patches included in the calculation : 4(0 1 2 3) Calculating view factors... Writing view factor matrix... F00: 0.53782006 F01: 0.10066795 F02: 0.31692687 F03: 0.062410839 F10: 0.49382079 F11: 0.4450708 F12: 0 F13: 0.20058446 F20: 1.0042635 F21: 0 F22: 0 F23: 0 F30: 0.31134188 F31: 0.20398426 F32: 0 F33: 0.52597451 End Code:
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 9 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 9-b456138dc4bc Exec : viewFactorsGen -region air -parallel Date : Mar 30 2023 Time : 14:26:22 Host : "ct-System-Product-Name" PID : 178341 I/O : uncollated Case : /home/ct/OpenFOAM/ct-9/run/iSTORE/iSTORE_conical_radiation_2 nProcs : 8 Slaves : 7 ( "ct-System-Product-Name.178342" "ct-System-Product-Name.178343" "ct-System-Product-Name.178344" "ct-System-Product-Name.178345" "ct-System-Product-Name.178346" "ct-System-Product-Name.178347" "ct-System-Product-Name.178348" ) Pstream initialised with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking polling iterations : 0 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh air for time = 0 [3] Creating single cell mesh... [0] Creating single cell mesh... [6] Creating single cell mesh... [4] Creating single cell mesh... [7] Creating single cell mesh... [1] Creating single cell mesh... [5] Creating single cell mesh... [2] Creating single cell mesh... [7] Created single cell mesh... [5] Created single cell mesh... [3] Created single cell mesh... [6] Created single cell mesh... [1] Created single cell mesh... [0] Created single cell mesh... Total number of coarse faces: 123 [0] View factor patches included in the calculation : 2(1 3) [4] Created single cell mesh... [2] Created single cell mesh... Calculating view factors... Writing view factor matrix... F11: 0.42525914 F13: 0.18779075 F31: 0.18889182 F33: 0.53471009 End That dictionary is the folloing Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 9.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object viewFactorsDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // writeViewFactorMatrix true; writeFacesAgglomeration true; writePatchViewFactors true; maxDynListLength 999999; debug 1; //dumpRays false; //true; free_air { nFacesInCoarsestLevel 20; featureAngle 5; } air_to_receiver_hot { nFacesInCoarsestLevel 20; featureAngle 5; } air_to_receiver_mid { nFacesInCoarsestLevel 20; featureAngle 5; } air_to_receiver_out { nFacesInCoarsestLevel 20; featureAngle 9; } // ************************************************************************* // 1.) What might be causing the discrepancy? Could it be a bug? Now I don't trust as much the validity of my simulation. 2.) What is the most appropriate way of combining the viewFactor model with the decomposePar, reconstructPar and post processing with functionObjects? |
February 16, 2024, 11:59 |
Hi Chris,
have you found an answer to your questions? I have now the very same experience in a similar case and it's making a headache, whether my parallel generated faceAgglomeration and viewFactors are correct. Regards |
March 20, 2024, 08:47 |
Chris
Rep Power: 4 |
Hi muanyagdino,
No I didn't find anything to satisfactory solve my problem. I'm still using the process described above. I haven't been working on this for a while now though. I'm only recently getting back to it. I'm wondering if the problem persist the same in OFv10 and OFv11 I'm using still version 9 from openfoam.org and I didn't get to try my problem on the newer versions. If I may ask what version are you working with. Best, Chris |
different results between serial solver and parallel solver | wlt_1985 | FLUENT | 11 | October 12, 2018 09:23 |
Slightly different results between parallel and serial run. Which results to trust? | h0rst | FLUENT | 10 | April 12, 2018 02:41 |
Different results between parallel and serial processing | Sarah_Fluent | FLUENT | 5 | March 6, 2018 12:42 |
The results difference between parallel and serial run. | Hkp | OpenFOAM Running, Solving & CFD | 2 | April 17, 2014 03:26 |
Serial vs parallel different results | luca | OpenFOAM Bugs | 2 | December 3, 2008 11:12 |
