Temperature average by codedFunctionObject
Like Tree2Likes
  • 2 Post By olesen
Old   March 6, 2023, 14:31
Post Temperature average by codedFunctionObject
george
scfd is on a distinguished road
I'm trying to get average value of temperature with additional statements, like if the Velocity magnitude is zero take that cell to account.
I've just 2 conditions.
  1. First one is the positional, check the cell z-position if it is between P1 and P2.
  2. Second one is the velocity magnitude.
If the cell satisfies the conditions, add the temperature value of that cell by Tm. Divide Tm by counter after the for loop.
temperatureAverage
    type coded;
    libs (utilityFunctionObjects);
    writeControl writeTime;
    name temp;
    codeWrite
	scalar P1 = 1.0;
	scalar P2 = 2.0;
	scalar Tm = 0;
	scalar TposAve = 0;
	scalar counter = 0;
        const scalarField& zPos= mesh().C().component(2);
        const volVectorField& U = mesh().lookupObject<volVectorField>("U");
	const volScalarField& T = mesh().lookupObject<volScalarField>("T");
	forAll(zPos,i)
		if (zPos[i] >= P1 && zPos[i] <= P2)
			if (U[i] > 0)
				Tm += T[i];
				counter += 1;
	TposAve = Tm/counter;
ERROR:
/aveTest/system/controlDict.functions.temperatureAverage: In member function ‘virtual bool Foam::tempFunctionObject::write()’:
/aveTest/system/controlDict.functions.temperatureAverage:96:14: error: no match for ‘operator>’ (operand types are ‘const Foam::Vector<double>’ and ‘int’)
I attached the log file for further reading.
regards,
scfd
scfd is offline   Reply With Quote
Old   March 6, 2023, 21:51
Post
george
Edit:
This one is works but it can't make a log file in postProcessing folder.
temperatureAverage
type coded;
name temp;
codeWrite
	scalar P1 = 1.0;
	scalar P2 = 2.0;
	scalar Tm = 0;
	scalar TposAve = 0;
	scalar counter = 0;
	forAll(zPos,i)
			if (sqrt(sqr(U[0][i])+sqr(U[1][i])+sqr(U[2][i])) > 0) //mag(U)[i]
				Tm += T[i];
				counter += 1;
				//Info<< "Tm = " << Tm << endl;
				//Info<< "Counter = " << counter << endl;
	Info<< "AVERAGE TEMPERATURE = " << TposAve << endl;
	//temp.write();
regards,
scfd
Old   March 9, 2023, 16:31
Post
george
Hi again,
Code runs correctly on buoyantPimpleFoam and returns the expected values, however it gives error on buoyantBoussinesSimpleFoam. There are only two difference on them. First case is transient and using boussinesq as EoS, the second one is steady-state and using directly boussinesq solver. I attached the log file.
What should I do to make it work in boussinesq solver as well?
ERROR:
    functionObjects::mag mag(U) writing field: mag(U)
[0] [1] ##0  0  Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&) at  at ??:?
[0] #1  Foam::sigFpe::sigHandler(int)[1] #1  Foam::sigFpe::sigHandler(int) at ??:?
[1] #2  ? at ??:?
[0] #2  ? in /lib64/libpthread.so.0
[1] #3  Foam::tempAveCodeFunctionObject::write() in /lib64/libpthread.so.0
[0] #3  Foam::tempAveCodeFunctionObject::write() at system/controlDict.functions.temperatureAverage:82
[0] #4  Foam::functionObjects::timeControl::write()[1] #4  Foam::functionObjects::timeControl::write() at ??:?
 at ??:?
[0] #5  Foam::functionObjectList::execute()[1] #5  Foam::functionObjectList::execute() at ??:?
[1] #6  Foam::Time::run() const at ??:?
[0] #6  Foam::Time::run() const at ??:?
[1] #7  Foam::Time::loop() at ??:?
[0] #7  Foam::Time::loop() at ??:?
 at ??:?
[1] #8  Foam::simpleControl::loop()[0] #8  Foam::simpleControl::loop() at ??:?
[1] #9   at ??:?
[0] #9  ?? at ??:?
[1] #10  __libc_start_main at ??:?
[0] #10  __libc_start_main in /lib64/libc.so.6
[1] #11   in /lib64/libc.so.6
[0] #11  ?? at ??:?
[82:291861] *** Process received signal ***
[82:291861] Signal: Floating point exception (8)
[82:291861] Signal code:  (-6)
[82:291861] Failing at address: 0x199000047415
 at ??:?
[82:291860] *** Process received signal ***
[82:291860] Signal: Floating point exception (8)
[82:291860] Signal code:  (-6)
[82:291860] Failing at address: 0x199000047414
[82:291861] [ 0] [82:291860] [ 0] /lib64/libpthread.so.0(+0xf370)[0x2b084f966370]
[82:291861] [ 1] /lib64/libpthread.so.0(raise+0x2b)[0x2b084f96623b]
[82:291861] [ 2] /lib64/libpthread.so.0(+0xf370)[0x2b297d50d370]
[82:291860] [ 1] /lib64/libpthread.so.0(raise+0x2b)[0x2b297d50d23b]
[82:291860] [ 2] /lib64/libpthread.so.0(+0xf370)[0x2b297d50d370]
[82:291861] [ 3] [82:291860] [ 3] /run/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libtempAveCode_5eeffd6dc79cd41527594d65478d16bbfc6b994f.so(_ZN4Foam25tempAveCodeFunctionObject5writeEv+0x1f0)[0x2b29a89216c0]
[82:291860] [ 4] /run/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libtempAveCode_5eeffd6dc79cd41527594d65478d16bbfc6b994f.so(_ZN4Foam25tempAveCodeFunctionObject5writeEv+0x1f0)[0x2b087aec96c0]
[82:291861] [ 4] /PATH/openfoam/of_2112/v2112/OpenFOAM-v2112/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam15functionObjects11timeControl5writeEv+0x5e)[0x2b297c2887ee]
[82:291860] [ 5] /PATH/openfoam/of_2112/v2112/OpenFOAM-v2112/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam15functionObjects11timeControl5writeEv+0x5e)[0x2b084e6e17ee]
[82:291861] [ 5] /PATH/openfoam/of_2112/v2112/OpenFOAM-v2112/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam18functionObjectList7executeEv+0x2df)[0x2b297c27bcaf]
[82:291860] [ 6] /PATH/openfoam/of_2112/v2112/OpenFOAM-v2112/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam18functionObjectList7executeEv+0x2df)[0x2b084e6d4caf]
[82:291861] [ 6] /PATH/openfoam/of_2112/v2112/OpenFOAM-v2112/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam4Time3runEv+0xdd)[0x2b297c29266d]
[82:291860] [ 7] /PATH/openfoam/of_2112/v2112/OpenFOAM-v2112/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam4Time3runEv+0xdd)[0x2b084e6eb66d]
[82:291861] [ 7] /PATH/openfoam/of_2112/v2112/OpenFOAM-v2112/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam4Time4loopEv+0x13)[0x2b297c2928d3]
[82:291860] [ 8] /PATH/openfoam/of_2112/v2112/OpenFOAM-v2112/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam4Time4loopEv+0x13)[0x2b084e6eb8d3]
[82:291861] [ 8] /PATH/openfoam/of_2112/v2112/OpenFOAM-v2112/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam13simpleControl4loopEv+0x85)[0x2b29789f0565]
[82:291860] [ 9] buoyantBoussinesqSimpleFoam[0x435e0b]
[82:291860] [10] /lib64/libc.so.6(__libc_start_main+0xf5)[0x2b297d73bb35]
/PATH/openfoam/of_2112/v2112/OpenFOAM-v2112/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam13simpleControl4loopEv+0x85)[0x2b084ae49565]
[82:291861] [ 9] buoyantBoussinesqSimpleFoam[0x435e0b]
[82:291861] [10] /lib64/libc.so.6(__libc_start_main+0xf5)[0x2b084fb94b35]
[82:291861] [11] [82:291860] [11] buoyantBoussinesqSimpleFoam[0x4387c1]
[82:291861] *** End of error message ***
[82:291860] *** End of error message ***
regards,
scfd
Old   August 22, 2023, 09:25
Smile
Elena
ElenaJL00 is on a distinguished road
Please did you resolved your problem, I have the same issue
ElenaJL00 is offline   Reply With Quote
Old   August 22, 2023, 10:20
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Don't be surprised to see a segfault or floating point exception with the original code, especially when running in parallel. You need to use the overall values when calculating any average and also need to protect against division by zero. If you do not perform the reduction, the answer will not only be incorrect but there is most certainly going to be one or more processor domains with zero cells that match your selection criteria and they will provoke a divide by zero.
Here is a slightly updated version of the code. Note that we avoid extracting the z-component up front. That is adds extra memory overhead - much better to get the z component on a per-cell basis.
temperatureAverage
    type coded;
    name temp;
    codeWrite
        const scalar P1 = 1.0;
        const scalar P2 = 2.0;
        const auto& cc = mesh().C();
        const auto& U = mesh().lookupObject<volVectorField>("U");
        const auto& T = mesh().lookupObject<volScalarField>("T");
         const label nCells = cc.size();
         scalar TposAvg = 0;
         label count = 0;
        for (label celli = 0; celli < nCells; ++celli)
            if
                (cc[celli].z() >= P1 && cc[celli].z() <= P2)
              && mag(U[celli]) > 0
                TposAvg += T[celli];
                ++count;
        reduce(TposAvg, sumOp<scalar>());
        reduce(count, sumOp<label>());
   // Or:
        // sumReduce(TposAvg, count);
        if (count)
            TposAvg = TposAvg/count;
            Info<< "AVERAGE TEMPERATURE = " << TposAvg << endl;
        else
            Info<< "AVERAGE TEMPERATURE = " << none << endl;
Probably makes more sense to have this type of code as 'execute()' instead of 'write()' since it is just reporting back values and not writing to disk.
scfd and ElenaJL00 like this.
olesen is offline   Reply With Quote
coded, coded function object, temperature average value
[openSmoke] libOpenSMOKE Tobi OpenFOAM Community Contributions 562 January 25, 2023 10:21
Converging Diverging Nozzle with dbnsTurbFoam Saleh Abuhanieh OpenFOAM Running, Solving & CFD 4 December 13, 2019 11:26
Area weighted average temperature vin95 Main CFD Forum 2 August 8, 2018 02:46
How can i export the average Temperature for many time steps from Fluent? benmel2006 FLUENT 1 April 5, 2017 14:32
average interior temperature less than the operating temperature Naher FLUENT 4 April 1, 2011 00:14
