How to use sixDoFRigidBodyMotion to provide mesh rotation withouth deforming the mesh |
February 6, 2023, 13:10 |
Eduardo Firvida
Rep Power: 16 |
Hi, I'm using sixDoFRigidBodyMotion to compute the rotation of NREL Phase IV wind generator rotor (~5m diameter). After waiting for some time the simulation started to explode. And I found that the mesh start to be deformed, (see the pictures). My case is basically the propeller example with the rotor geometry and changing the dynamicMeshDict to:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2112 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object dynamicMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // report yes; reportToFile yes; dynamicFvMesh dynamicMotionSolverFvMesh; motionSolverLibs (libMySixDoFRigidBodyMotion); motionSolver sixDoFRigidBodyMotion; patches (rotor); innerDistance 0; outerDistance 6; orientation ( 1 0 0 0 1 0 0 0 1 ); mass 577.3; centreOfMass (-1.850E-07 -0.009 2.911E-08); momentOfInertia (3416.204 3420.038 13.145); angularMomentum (0 0 0); g (-9.81 0 0); rho rhoInf; rhoInf 1; report on; solver { type symplectic; } constraints { oCenter { sixDoFRigidBodyMotionConstraint point; centreOfRotation $centreOfMass; } yAxis { sixDoFRigidBodyMotionConstraint axis; axis (0 1 0); } } restraints { } // ************************************************************************* // |
November 14, 2023, 06:36 |
Manuel Fermin Fonseca
Rep Power: 12 |
Hello, could you solve, it has happened like me, change your inner diameter to a rotor the AMI diameter.
ami, motion dynamicmesh, sixdofmotionsolver |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! | divergence | OpenFOAM Meshing & Mesh Conversion | 0 | January 23, 2019 05:17 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
