Error in createPatch
Like Tree1Likes
  • 1 Post By gmori
Old   December 14, 2022, 13:22
Default Error in createPatch
mo
gmori is on a distinguished road
Hello everyone.
I am looking to install a small ventilation opening on the ceiling surface of a simple rectangular model, and I am planning to use topoSet and createPatch for this purpose.
The topoSetDict and createPatchDict are attached below.
topoSetDict:
| \\ / O peration | Version: v2006 |
| \\ / A nd | Website: www.openfoam.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object topoSetDict;
actions
// inlet
name f0;
type faceSet;
action new;
source boxToFace;
box (0.19000 0.39000 3.49000)(0.59600 0.791 100);
// outlet
name f1;
type cellSet;
action new;
source boxToFace;
box (5.40000 3.20000 3.49000)(5.81000 3.61000 100);
createPatchDict:
FoamFile
version 2.0;
format ascii;
class dictionary;
object createPatchDict;
pointSync false;
patches
name "inlet";
patchInfo
type patch;
constructFrom set;
set f0;
name "outlet";
patchInfo
type patch;
constructFrom set;
set f1;
However, when I do the createPatch, I get the following error.
Create time
Create polyMesh for time = 0
Reading "system/createPatchDict"
Adding new patch inlet as patch 14 from
type patch;
Adding new patch outlet as patch 15 from
type patch;
Read 64 faces from faceSet f0
--> FOAM FATAL IO ERROR:
unexpected class name cellSet expected faceSet
while reading object f1
file: /home/gaito/OpenFOAM/gaito-v2006/run/honban2/constant/polyMesh/sets/f1 at line 15.
From Foam::Istream& Foam::regIOobject::readStream(const Foam::word&, bool)
in file db/regIOobject/regIOobjectRead.C at line 170.
FOAM exiting
If anyone knows anything about this, please let me know. Also, I would like to know if there is any other way to add a small ventilation opening on a certain surface.
Thank you in advance.
gmori is offline   Reply With Quote
Old   December 15, 2022, 04:19
Yann
Yann will become famous soon enoughYann will become famous soon enough
Lets go step by step. Here is your error:
the object f1 is expected to be a faceSet, but it is actually a cellSet.
Now lets have a look at your topoSetDict:
// outlet
name f1;
type cellSet;
action new;
source boxToFace;
As you can see in topoSetDict, f1 is created as a cellSet rather than a faceSet, contrary to f0.
Cheers,
Yann
Yann is offline   Reply With Quote
Old   December 15, 2022, 04:33
mo
Hello.
Thank you for your reply!
I had overlooked the basics.
I changed it to faceset and it worked. Thank you!
Yann likes this.
[mesh manipulation] createpatch not working when using layer addition in snappyHexMesh Dikkeunit OpenFOAM Meshing & Mesh Conversion 0 February 3, 2020 10:46
createPatch cyclic boundary condition KateEisenhower OpenFOAM Pre-Processing 3 September 4, 2018 15:30
There is a bug in createPatch? feno102 OpenFOAM Pre-Processing 6 November 1, 2017 03:24
createPatch Segmentation Fault (CORE DUMPED) sam.ho OpenFOAM Pre-Processing 2 April 21, 2014 03:01
[Salome] unv mesh corrupted after createPatch maddalena OpenFOAM Meshing & Mesh Conversion 1 February 18, 2010 08:43
