How to choose solvers
Like Tree4Likes
  • 4 Post By dlahaye
Old   October 12, 2022, 12:52
Default How to choose solvers
Nico
Hr_kules is on a distinguished road
i have a pretty general question regarding the fvsolution file. I mostly worked from tutorial cases and chaged them according to my needs in terms of mesh and boundary conditions. However i am uncertain how one would choose configurations like the following:
solvers
    p
        solver           GAMG;
        smoother         symGaussSeidel;
        tolerance        1e-7;
        relTol           0.01;
    "(U|h|k|epsilon).*"
        solver           PBiCGStab;
        preconditioner   DILU;
        tolerance        1e-7;
        relTol           0.1;
Are there any ressources that touch that topic?
Hr_kules is offline   Reply With Quote
Old   October 12, 2022, 14:47
Domenico Lahaye
dlahaye is on a distinguished road
pressure in incompressible case: matrix is symmetric and positive definite: pressure is best solved using GAMG as preconditioner for CG in sequential;
pressure in compressible case, velocity components and parallel computing: use DILU as preconditioner for PBiCGStab;
Literature on the matter is vast. Possible entry point is https://netlib.org/templates/templates.pdf and references listed.
Yann, Hr_kules, songyi719 and 1 others like this.
dlahaye is offline   Reply With Quote
GPU Linear Solvers for OpenFOAM gocarts OpenFOAM Announcements from Other Sources 37 August 17, 2022 15:22
[TUTORIAL] Run fluent on distributed memory with 2 windows 7 64 bit machines ghost82 FLUENT 54 February 9, 2022 04:32
Question about buoyant Solvers estang OpenFOAM Programming & Development 1 February 7, 2017 13:26
Is there a difference between Riemann solvers and characteristic based solvers? linkamp Main CFD Forum 3 February 18, 2016 10:12
FSI solvers - best solvers steven123 OpenFOAM Running, Solving & CFD 0 July 8, 2014 11:26
