mapFields - only internalFields
Like Tree1Likes
  • 1 Post By MaxxiKing
Old   September 13, 2022, 11:43
Default mapFields - only internalFields
Österreich
MaxxiKing is on a distinguished road
Hello everyone,
I try to map the fields from a chtMultiRegionSimpleFoam case to a new chtMultiRegionSimpleFoam case with other boundary conditions.
Therefore I run the command:
mapFields {source_workdir} -case {workdir} -sourceTime '{latest_time}' -sourceRegion {source_region} -targetRegion {target_region} -consistent
But after running mapFields, the boundary conditions in the {workdir} are overwritten by the boundary conditions of the {source_workdir}.
I have tried to map only the internalField with the help of this post (using a mapFieldsDict with empty patchMap and cuttingPatches), but the boundary conditions are still overwritten.
Does anyone know how to map only the internalFields?
Thank you very much!
I am using openFoam Version 2206
MaxxiKing is offline   Reply With Quote
Old   September 16, 2022, 06:10
Österreich
I found a solution:
  1. map the fields
  2. convert each region from binary to ascii with
    foamDictionary {case_dir}/system/controlDict -entry writeFormat -set ascii
    foamFormatConvert -region {region}
  3. update the boundary conditions with foamDictionary with e.g.:
    'foamDictionary {case_dir}/0/{region}/T -entry "boundaryField/{patch}/h" -set "uniform 25.0"'
    to set h in externalWallHeatFluxTemperature:
    boundaryField
        a4ee84fced4c0414bbd71e87bf9631bc6
            type            externalWallHeatFluxTemperature;
            mode            coefficient;
            Ta              uniform 268.15;
            h               uniform 25;
            kappaMethod     solidThermo;
            value           nonuniform List<scalar>
            132
            268.306
  4. convert from ascii to binary with
    foamDictionary {case_dir}/system/controlDict -entry writeFormat -set binary
Giwrgos K likes this.
Old   February 1, 2024, 07:21
Default mappingFields maps the patches
Franco
fconcli is on a distinguished road
To avoid to map the fields you need a mapFieldsDict with an empty field "patchMap"... moreover, remove the "consistent" option when mapping.
fconcli is offline   Reply With Quote
internalfield, mapfields
running mapFields in parallel mkhm OpenFOAM Pre-Processing 10 September 16, 2021 14:12
mapFields & mapFieldsPar decompose cases otaolafr OpenFOAM Pre-Processing 2 August 26, 2021 14:13
Personalization of mapFields and libsampling - Compilation issues saimat OpenFOAM Programming & Development 3 June 29, 2016 09:56
Strange random behaviour of mapFields blaise OpenFOAM Pre-Processing 0 November 3, 2014 10:37
The -parallel parameter of mapFields utility in OpenFOAM v2.3.0 shuoxue OpenFOAM Pre-Processing 1 April 28, 2014 06:59
