Rep Power: 4 ![]() |
Hello foamers.
I'm using a multiphase solver (interCondensatingEvaporatingFoam). In the transport properties, both gas and liquid have "hf" to be defined. I searched in the documentation, but only found "Hf" which corresponds to the heat of fusion. I was pretty sure "hf" wasn't "Hf". I tried changing hf in Hf and the simulation crashed, so I'm now sure that it's not the heat of fusion. I thought it might be the specific enthalpy, but couldn't find anything sure about it. Anyone have the answer? |
Jinghan WANG
Rep Power: 0 ![]() |
Hello, I don't know if you have already solved this problem.
But since that there is no solution posted, I decide to reply. The hf means latent heat with unit[J/kg] in interCondensatingEvaporatingFoam cases. If you want to set latent heat of evaporation to 2256kJ/kg, you can just leave the hf of liquid as 0, and set the value of hf of vapour as 2256e3. Another forum page related to this issue: Mass transfer model in interCondensatingEvaporatingFoam Hope this can help you or others who has the same question. |
hf_property, multiphase, transportproperties |
Accessing transportProperties from coded functionObject | Shibi | OpenFOAM Programming & Development | 1 | April 19, 2021 15:26 |
How to read multiphase parameters in creatFields from Transportproperties ? | Amirhosseinesh | OpenFOAM Programming & Development | 4 | October 12, 2018 10:28 |
Dam break tutorial - transportProperties issue | Guimloute | OpenFOAM Running, Solving & CFD | 4 | June 27, 2017 11:52 |
Convert volScalarField to dimensionedScalar to be defined in transportProperties | sabago | OpenFOAM Programming & Development | 8 | June 1, 2015 12:11 |
Lookup transportproperties from BC | michielm | OpenFOAM Running, Solving & CFD | 4 | April 29, 2012 06:48 |
