March 10, 2022, 09:22 |
rotating mesh worsens mesh quality
Rep Power: 8 |
hi all,
i have a mesh which i want to rotate. so i use $ rotateMesh "(0 -1 0)""(0 1 0)" it rotates the geometry, but the mesh quality becomes really bad. screenshots are attached. same happens with $transformPoints -rotate ... hope someone can help |
March 14, 2022, 11:41 |
Rep Power: 21 |
That's because you are inverting your mesh. I.e every cell is inside out from that rotation.
try Code:
transformPoints -rotate-angle '((0 1 0) 180)' |
March 21, 2022, 03:25 |
#3 | |
Rep Power: 8 |
the following command did the trick: transformPoints -rollPitchYaw "(180 0 0)" |
mesh quality, rotatemesh |
[snappyHexMesh] non uniform mesh near the stl object | vava10 | OpenFOAM Meshing & Mesh Conversion | 0 | January 31, 2021 14:41 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
mesh quality and independency..!?? | michelle | CFX | 0 | October 15, 2007 05:50 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
