Add heat source on chtMultiRegionFoam
Like Tree1Likes
  • 1 Post By abhishekmonu96`
Old   February 8, 2022, 02:45
Default Add heat source on chtMultiRegionFoam
Giulia
letoppina is on a distinguished road
I want to simulate a heated tube (that is able to generate heat) with water flowing inside. How can I add the heat source to the solid region (my tube)? In my case, I am using [J/kg] as unit for the heat source.
Thank you in advance your kind help.
P.S. I am using OpenFoam 6
letoppina is offline   Reply With Quote
Old   February 8, 2022, 14:46
abhishekmonu96` is on a distinguished road
Hi letoppina,
You can provide heat source term in fvOptions dictionary. This dictionarycan be generated in any region directory in which you want to implement heat source term addition.
you can find tutorials for that in :
https://github.com/OpenFOAM/OpenFOAM...ltiRegionFoam/
letoppina likes this.
abhishekmonu96` is offline   Reply With Quote
Old   March 2, 2022, 01:39
hari charan
saicharan662000@gmail.com is on a distinguished road
Hello giulia,
I am not a user of chtMultiRegionFoam.But What I do to add source term is use Su,Sp terms in governing equations,In my case I add the directly in alpha equation or Peqn or Ueqn .
saicharan662000@gmail.com is offline   Reply With Quote
fvoptions mass source, heat source term, heat sources
[swak4Foam] swak4foam for OpenFOAM 4.0 mnikku OpenFOAM Community Contributions 80 May 17, 2022 09:06
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 12:32
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 13:41
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
