OpenFOAM-v2112 function fieldValueDelta missing |
Mario Javier Rincón
Rep Power: 5 ![]() |
Hi guys,
I recently installed the new ESI version of OpenFOAM (v2112) and try to run a quite complete simulation that I programmed in v2006. The simulation yields the pressure drop data between inlet and outlet with the function fieldValueDelta, however, it seems that v2112 does not include this function. Code:
--> FOAM Warning : Unknown function type fieldValueDelta |
Yann
Rep Power: 27 ![]() |
The fieldValueDelta function object has been replaced by the multiFieldValue function : https://develop.openfoam.com/Develop...tiFieldValue.H Cheers, Yann |
fieldvaluedelta, function, pressure drop, v2112 |
[mesh manipulation] RefineMesh Error and Foam warning | jiahui_93 | OpenFOAM Meshing & Mesh Conversion | 4 | March 3, 2018 11:32 |
[mesh manipulation] refineMesh Error | mohsen.boojari | OpenFOAM Meshing & Mesh Conversion | 3 | March 1, 2018 22:07 |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 10:51 |
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 04:37 |
Droplet Evaporation | Christian | Main CFD Forum | 2 | February 27, 2007 06:27 |
