interCondensatingEvaporatingFoam and Heat flux
Like Tree1Likes
  • 1 Post By Almanzo2000
Old   December 1, 2021, 07:36
Default interCondensatingEvaporatingFoam and Heat flux
L S
silviliril is on a distinguished road
How to provide constant heat flux boundary condition with interCondensatingEvaporatingFoam ?
I have this long standing question and haven't got an answer yet. I am wondering if someone has solved it.
silviliril is offline   Reply With Quote
Old   April 6, 2022, 05:58
roham seif
Roham..Seif is on a distinguished road
You can use the type externalWallHeatFluxTemperature for the wall, so you can have a fixed heat flux (for example 20000 [kW/m2]).
Check this out too:
https://www.youtube.com/watch?v=PCGaw57x59w
Roham..Seif is offline   Reply With Quote
Old   May 10, 2023, 08:41
kanata is on a distinguished road
in 2023 I still have this problem. the externalWallHeatFluxTemperature BC is unavailable for interCondensatingEvaporatingFoam.
kanata is offline   Reply With Quote
Old   April 16, 2024, 15:06
morphadron is on a distinguished road
Is there a way to add this BC manually to interCondensatingEvaporatingFoam, such as adding some libraries to original solver, make files etc. ?
morphadron is offline   Reply With Quote
Old   December 16, 2024, 23:28
Almanzo Arjuna
Almanzo2000 is on a distinguished road
You can edit the Make/options file and add "-lthermoTools" in the EXE_LIBS part, compile the solver and you should be able to use externalWallHeatFluxTemperature
kanata likes this.
Almanzo2000 is offline   Reply With Quote
boiling, intercondensatingevaporat, openfoam, phase change heat foam
Write heat Flux Expression and Define a Heat Flux boundary Condition in Wall. MNMK CFX 5 October 12, 2021 03:36
Heat Flux versus Wall Heat Flux: inlet - outlet energy, different values jmenendez CFX 1 February 14, 2021 17:55
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Forced convective heat transfere with fixed heat flux? BenFranklinIII OpenFOAM Running, Solving & CFD 0 July 30, 2015 06:31
Enforce bounds error with heat loss boundary condition at solid walls Chander CFX 2 May 1, 2012 21:11
