problems on dsmc FreeStream Inflow Field Patch setup |
July 23, 2021, 15:59 |
Lucas Lima
Good morning, Im perfoming an validation experiment for a paper on dsmcFoam+
one of the simulation requirements is a non-uniform, vector list (U, T, numerical density) reading the source code i came across this boundary condition: Code:
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | \\ / A nd | Copyright (C) 2016-2021 hyStrath \\/ M anipulation | ------------------------------------------------------------------------------- License This file is part of hyStrath, a derivative work of OpenFOAM. OpenFOAM is free software: you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free Software Foundation, either version 3 of the License, or (at your option) any later version. OpenFOAM is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details. You should have received a copy of the GNU General Public License along with OpenFOAM. If not, see <http://www.gnu.org/licenses/>. Class dsmcFreeStreamInflowFieldPatch Description Fully deletion boundary patch: atomisticMolecules get deleted instantly upon collision with a face on the boundary. (aka vacuum boundary condition) Selective deletion of one specie is possible. Other species get specularly reflected. SourceFiles dsmcFreeStreamInflowFieldPatch.C \*---------------------------------------------------------------------------*/ #ifndef dsmcFreeStreamInflowFieldPatch_H #define dsmcFreeStreamInflowFieldPatch_H #include "dsmcGeneralBoundary.H" #include "vector.H" #include "polyMesh.H" #include "volFields.H" #include "dsmcCloud.H" #include "distribution.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // namespace Foam { /*---------------------------------------------------------------------------*\ Class dsmcFreeStreamInflowFieldPatch Declaration \*---------------------------------------------------------------------------*/ class dsmcFreeStreamInflowFieldPatch : public dsmcGeneralBoundary { private: // Private data dictionary propsDict_; labelList typeIds_; //vector so different translational, rotational //vibrational temperatures can be set vectorField inletTemperatures_; vectorField inletVelocities_; // list of (one value) mass densities corresponding to the type Ids List <scalarField> numberDensities_; // list of species List <scalarField> accumulatedParcelsToInsert_; //- boundary temperatures volVectorField boundaryT_; //- boundary velocity volVectorField boundaryU_; //- list of inlet densities (one entry for each species) List<autoPtr<volScalarField> > boundaryNumberDensity_; void setProperties(); public: //- Runtime type information TypeName("dsmcFreeStreamInflowFieldPatch"); // Constructors //- Construct from components dsmcFreeStreamInflowFieldPatch ( Time& t, const polyMesh& mesh, dsmcCloud& cloud, const dictionary& dict ); // Destructor ~dsmcFreeStreamInflowFieldPatch(); // Member Functions void initialConfiguration(); //- calculate any required properties void calculateProperties(); //- control the mols void controlParcelsBeforeMove(); void controlParcelsBeforeCollisions(); void controlParcelsAfterCollisions(); //- output data void output ( const fileName& fixedPathName, const fileName& timePath ); //- update properties from a modified dictionary void updateProperties(const dictionary&); //reset fields if mesh has changed void setNewBoundaryFields(); // Access }; // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // } // End namespace Foam // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // #endif // ************************************************************************* // Code:
boundary { generalBoundaryProperties { patchName outflow; } boundaryModel dsmcFreeStreamInflowFieldPatch; dsmcFreeStreamInflowFieldPatchProperties { typeIds (N2cold); boundaryU N2cold 100 ( (719.1304875090954 25.172575474152957 0) (719.3627785226914 26.328806602546166 0) (719.5950695362875 27.29233254287383 0) (719.8273605498836 28.54491626529981 0) (720.0596515634796 29.604794799660247 0) (720.2919425770757 30.857378522086222 0) ... ); boundaryT N2cold 100 ( (8.988987042333086 8.988987042333086) (8.98943049818169 8.98943049818169) (8.9907608657275 8.9907608657275) (8.992638162153256 8.992638162153256) ... ); boundaryNumberDensity N2cold 100 ( (6.804743383294108) (6.80455480107654) ... ); } } Code:
[0] cannot find file [0] [0] file: /home/nanor4k/openfoam/hyStrath/run/hyStrath/dsmcFoam+/supersonicFlatPlate2/processor0/0/boundaryT at line 0. [0] [0] From function regIOobject::readStream() [0] in file db/regIOobject/regIOobjectRead.C at line 237. Code:
--> FOAM FATAL IO ERROR: [5] attempt to read beyond EOF best regards nanoR4K. |
July 19, 2022, 11:38 |
Alexander Cushen
Rep Power: 4 |
The usage of dsmcFreeStreamInflowFieldPatch boundary condition is a bit different. To operate it as you intend, I would recommend:
1. Setup your simulation to work normally with dsmcFreeStreamInflowPatch (ie a uniform boundary condition), and I strongly recommend you set the inlet mesh geometry to be a nice uniform square/rectangle. 2. Run your dsmcFreeStreamInflowPatch for a few time steps to generate directories which save the state of the system at a given time (ie "0.00355"). Inside these are a number of files of type "volVectorField" and "volScalarField". We need these as a template to set up the custom boundary conditions. 3. Stop your simulation, and in "boundariesDict" change the boundary type for your inlet patch from "dsmcFreeStreamInflowPatch" to "dsmcFreeStreamInflowFieldPatch" and also replace "dsmcFreeStreamInflowPatchProperties" with "dsmcFreeStreamInflowFieldPatchProperties"; don't change or add anything else in that file except for those names for the patches you want to modify. 4. Now you need to set up the 3 custom boundary condition files in the "0" directory. Using the files generated earlier as a template, create a file named "boundaryT" in the "0" directory which is a volVectorField (by copying in for instance a file from the state directory "0.00355" which corresponds to the velocity of all the cells). When you open this file, change its name next to "object" to "boundaryT". Below that, you will see a couple of large vector lists, one for the internalField, and more below for each other boundary. Go to the vector list corresponding to your inlet patch; each vector (x y z) corresponds to the translational, rotational, vibrational temperature of each cell on that boundary. You can now change the values of each vector to match your desired boundary profile (you might need to play around to see the order that dsmcFoam reads the list onto the 2D boundary). You can ignore the values for the other patches / internalField, as they will be ignored by Foam (although they need to be left there for the syntax to work). 5. Repeat analogously for the velocity profile, by adding a "boundaryU" file to the "0" directory, again using a volVectorField file as a template. Here, each vector (x y z) is just the 3D velocity vector on the boundary patch. 6. Lastly, for number density, you need a volScalarField file, named "boundaryNumberDensity_<species name>" (eg boundaryNumberDensity_O2). 7. All set! |
December 17, 2023, 05:03 |
lihui
Rep Power: 4 |
Hello, have you ever encountered a problem with the calculation of automatic stops when running dsmcfoam+? This question has been bothering me.
boundary condition, dsmcfoam+, vector field, volvectorfield |
[swak4Foam] swakExpression not writing to log | alexfells | OpenFOAM Community Contributions | 3 | March 16, 2020 19:19 |
[Other] dynamicTopoFVMesh and pointDisplacement | RandomUser | OpenFOAM Meshing & Mesh Conversion | 6 | April 26, 2018 08:30 |
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) | Aadhavan | OpenFOAM Meshing & Mesh Conversion | 2 | March 8, 2018 02:47 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 07:51 |
