May 19, 2021, 05:51 |
boatAndPropeller tutorial with actuator disk
Rep Power: 6 |
Hi Foamers,
I'm working on ship self-propulsion and I'm using OF-v2006 and overInterDyMFoam. My question is : how to replace the propeller in the tutorial boatAndPropeller by an actuator disk ? I want to fix the actuator disk to the ship, so that they can move together. Indeed, the ship is free in surge, pitch an heave. I thank you in advance for your help! Best regards, Alix |
May 19, 2021, 16:29 |
Herpes Free Engineer
Rep Power: 13 |
To model an actuator disk, I think you can use one of the following fvOptions:
actuationDisk rotorDisk radialActuationDisk Hope these help.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
May 20, 2021, 08:27 |
#3 | |
Rep Power: 6 |
Dear Herpes, Thanks for your reply. I am already using actuationDisk from fvOptions and I want to know if it's possible connect the actuationDick to the ship. For example in the boatAndPropeller tutorial (OF-v2006) the propeller (rigidBody) is connected to the ship in dynamicMeshDict thanks to the "joint" option from the rigidBodyMeshMotion library. I tried to replace the propeller by the actuator disk but it did not work since it's not a rigidBody. Have you got an idea on how to connect the actuator disk to the ship ? Thank you! Best regards, Alix |
May 20, 2021, 16:32 |
Rep Power: 13 |
Oh, I see.. Very interesting. I am afraid, I don't think there is out of box functionality to perform this. I think you will need to modify the relevant utilities.
A similar utility, moving body forces, is the actuator-line model with tilting motion of the rotor plane. There are few repos providing implementations in GitHub for this model (one is SOWFA). Maybe you can fetch several things from those implementations. I think the most challenging part could be the parallelisation. I hope somebody more knowledgeable than me can indicate an existing utility to allow movement of body forces.
January 31, 2022, 04:19 |
Ship with actuator disc
#5 | |
Sachin
Rep Power: 12 |
I am also interested in similar problem.where you able to find a solution for this? |
January 31, 2022, 07:49 |
Rep Power: 6 |
actuator disk, naval, overinterdymfoam, propeller, ship motion |
tutorial files | KITetima | FLUENT | 8 | November 23, 2019 16:05 |
AMI - Propeller Tutorial diverging | kingmaker | OpenFOAM Running, Solving & CFD | 2 | November 4, 2016 02:57 |
Tutorial For Workbench CFX Remesh | ashtonJ | CFX | 2 | April 26, 2014 21:19 |
Fluent Tutorial Guide Ch. 17: Non-Premixed Combust, THTR | MAE7509 | FLUENT | 0 | January 22, 2014 20:59 |
STAR-CD Tutorial | shekhar aryal | STAR-CD | 4 | March 22, 2010 03:25 |
