Error importing CSV File as Boundary in OpenFOAM |
April 27, 2021, 06:09 |
Goodmorning,
i'm new to the forum and also to using OpenFOAM. It's been three days that i'm trying to import a csv file as inlet boundary condition for my simulation. I think to use the right code string, but i don't understand where can be the error. The following is the code string: inlet { type uniformFixedValue; uniformValue { type csvFile; nHeaderLine 0; refColumn 0; componentColumns (1); separator ","; mergeSeparators no; file "inlet.csv"; { } And the following is the error when i try to run the analysis: --> FOAM FATAL ERROR: Unknown Function1 type csvFile for Function1 uniformValue Valid Function1 types are: 17 ( coded constant halfCosineRamp linearRamp one polynomial quadraticRamp quarterCosineRamp quarterSineRamp reverseRamp scale sine square table tableFile uniform zero ) From function static Foam::autoPtr<Foam::Function1<Type> > Foam::Function1<Type>::New(const Foam::word&, const Foam::dictionary&) [with Type = double] in file /home/ubuntu/OpenFOAM/OpenFOAM-8/src/OpenFOAM/lnInclude/Function1New.C at line 48. FOAM exiting If someone has some solution he'll be gratefull. Thank you, and sorry if someone in the forum has already posted the same question, but i didn't find it. |
May 27, 2021, 23:31 |
John
Rep Power: 7 |
Hi - you need to provide a bit more information on your problem and case. A good start would be your 0 folder files and some idea of the axial relationships in your geometry. Maybe a pic of your geometry - I assume you've meshed ok.
Regards base |
June 1, 2021, 08:29 |
I solved it. Thank you. It was a problem with the installed version of Openfoam.
June 2, 2021, 00:24 |
John
Rep Power: 7 |
Hi Aydan - the idea of sharing in the forums is that if you ask for help and then solve the problem - you share that solution with others so they don't have to suffer the same torture - it's the community thing. Thanks, Regards
July 7, 2021, 08:45 |
[SOLVED] Read bundary condition from csv file
Asmaa
Rep Power: 10 |
Here is a working example of how to read velocity of a boundary condition from csv file:
inlet { type fixedProfile; profile tableFile; profileCoeffs { format csv; // Input format nHeaderLine 1; // Number of header lines refColumn 11; // Reference column index componentColumns (0 1 2); // Component column indices separator ","; // Optional (defaults to ",") mergeSeparators yes; // Merge multiple separators outOfBounds clamp; // Optional out-of-bounds handling file "input/U_k_epsilon.csv"; interpolationScheme linear; // Optional interpolation scheme } direction (0 1 0); origin 0; } |
boundary, csv, import, openfoam |
Using PengRobinsonGas EoS with sprayFoam | Jabo | OpenFOAM Running, Solving & CFD | 36 | July 16, 2024 04:52 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 22:53 |
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 | towanda | OpenFOAM Community Contributions | 6 | September 5, 2015 22:03 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 02:41 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 12:44 |
