Help with simulating a deforming / morphing wing |
January 13, 2021, 21:29 |
TWB
Rep Power: 19 |
I have a wing which will performed prescribed morphing at different instants in time. I have the STL of the wing at t = 0, t = 0.5, t = 1.0. The deformation is relatively large, around 1 chord length in some regions. So is it possible to perform this sort of simulation in OF? If so, what is the best way to do it? There was an old thread which discusses something similar: Morph mesh given displacement of boundary points I also saw a new feature in OF 1806: https://www.openfoam.com/releases/op...nd-physics.php which has a twistingcolumn. I wonder if it's applicable too. Thanks! |
March 16, 2022, 01:33 |
Morhing in openfoam
Rep Power: 14 |
Hi. I am trying to conduct a similar simulation. Dd you find a method to do morphing in openfoam? If yes, please let me know.
Thanks, |
February 22, 2024, 23:57 |
TWB
Rep Power: 19 |
Hi toolpost,
You can look over here: Possible to have both solidBodyMotionFunction rotatingMotion + displacementLaplacian? |
Ffd_control_point_2d | feiyi | SU2 | 4 | September 30, 2019 12:42 |
Dynamic Meshing for in plane morphing wing | Aidan100 | FLUENT | 3 | September 5, 2015 01:00 |
[Other] Morphing wing cfd analysis in transition | rekfuh | ANSYS Meshing & Geometry | 0 | June 6, 2012 09:22 |
simulating wing motion of an insect??? | sanjay | STAR-CCM+ | 8 | May 11, 2012 17:40 |
Simulating articulated wing of an ornithopter | xyzch001 | Fluent UDF and Scheme Programming | 0 | January 24, 2012 09:06 |
