Wierd results after running setFields without getting an error in terminal
Like Tree1Likes
  • 1 Post By simrego
Old   January 12, 2021, 21:11
Exclamation Wierd results after running setFields without getting an error in terminal
Deutschland
vava10 is on a distinguished road
Hey everyone,
I am trying to create my own case wich involve VOF method. I apply setFields and I don't get any error in the Ubuntu terminal. But when I open the alpha.water file which is formed after running the setFields, it doesn't have 0 and 1. Instead, it has "?", "ð?" and blank space. I have attached the file along with this. I went through a lot of errors related to setFields which was posted in this forum and couldn't find any similar to this and I don't know why I get such an alpha.water file after running setFields. So I could not search for a specific error
alpha.water.txt
Does anyone have any idea why I get this error?
Thank you in advance
Kind regards
vava10
vava10 is offline   Reply With Quote
Old   January 14, 2021, 09:43
anonymous
simrego is on a distinguished road
Hi!
What is your setting for the "writeFormat" in system/controlDict? If it is binary then this is totally normal. If it is ascii then there are some serious problems...
BTW: This is not an error. If there is an error, OF will tell you with nice big ERROR messages.
vava10 likes this.
simrego is offline   Reply With Quote
Old   January 15, 2021, 11:48
Deutschland
Hey,
Thank you for your reply. It is binary.
I was not able to visualize the setfields result in ParaView for some reason. I thought this could be the reason.
Do you have any idea why I am not able to visualize the result in ParaView? Can you suggest to me what I might have done wrong? Like the usual reasons this might occur from your experience with the software so that I can check them.
Old   January 15, 2021, 12:12
anonymous
Blindly I would guess that you left the "skip zero time" option checked (by default) in paraview, and your resulted field is in the 0 time folder so paraview won't read it.
If this is not the problem then you should attach your case or give more information.
Running transient with steady results as initial conditions cwl STAR-CCM+ 4 November 29, 2016 10:31
Problem: Very long "write" time (~2h-3h) for results and transient results Shawn_A CFX 16 April 12, 2016 21:49
[OpenFOAM] icoFsiElasticNonLinULSolidFoam (foam-extend 3.1)>>How to see results with paraFoam? steven123 ParaView 7 December 5, 2015 03:34
Unsteady Simulation - Wierd results from Fluent nikhil FLUENT 3 October 3, 2011 08:13
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 10:38
